Electric fan harness
Old May 9, 2015 | 10:15 PM
Go5.3tt06's Avatar
Default Electric fan harness
Installed my friend truck 2004 that we order efan and harness from lsx just chevy trucks.com. Have you hear this? Okay I need your help. I have small problem. I kinda confuse try to understand the instruction. I have poor English being hearing impaired. Forgive me again.
When I pull the ECM. Blue cover so I inserted into pin 42 with green wire. And inserted into pin 33 for blue wire in same blue cover. Fans still not
Work anything. Turn ac on and not turn fan. Over 210 temp won't do anything. I readed over and over on the instruction. They say connector 2 which other green cover that mean I need insert pin 33 for blue wire? If
It is that one. I have to go back and re-do pin. Let me know.
Old May 10, 2015 | 04:50 AM
alowerlevel's Avatar
The Green wire goes to pin 42 in the blue covered connector, this is fan 1.
The Blue wire goes to pin 33 in the green covered connector, this is fan 2.
And you also have to have a tuner or someone with the software (hp tuners, efi live, etc) enable the fans in the pcm
Old May 10, 2015 | 06:02 AM
Go5.3tt06's Avatar
So can't drive? Will they turn fans on when temp go up 210 degree? Or still have to get tuner do it?
Old May 10, 2015 | 11:41 AM
Go5.3tt06's Avatar
I repin to correct one. For blue wire go to #33 on green connector. The green wire stay in #42 on blue connector. I let run on and drive. I see temp start go up to over 215 and I check fans if they turn on. It still not. Any idea.
Old May 10, 2015 | 11:44 AM
1994Vmax's Avatar
If you have not had the truck tuned with HP or EFILive it will not turn the fans on as the bits in the PCM are not enabled to do so. The truck needs tuning changes to make the fans work. They will not ever come on with a stock 2004 clutch fan trucks tune!
Old May 10, 2015 | 03:16 PM
You MUST activate them in the tune!
Old May 10, 2015 | 06:34 PM
cammed00's Avatar
You have answered your own question...they have to be tuned in
Old May 10, 2015 | 10:39 PM
Go5.3tt06's Avatar
That what paper say need to tune. I thought it can be somehow work for temp. But I see this comment. I got it. Many thanks. We will take PCM sent to place to tune. I really appericate for your help and feedback. I'm learn something new now.
Old May 10, 2015 | 10:42 PM
cammed00's Avatar
You could put the power wire in the furl pump relay under the hood for temporary like I did until I got my LS Performance Wiring harness...it would constantly run though
SS94S10
Jan 3, 2019 01:57 PM
Silver8ado
Sep 30, 2015 11:42 AM
zraffz
Sep 20, 2015 08:25 PM
97gmc
22
Sep 8, 2015 10:56 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
