EGR removal or block off
Old Jun 2, 2005 | 04:50 AM
TX_Z71's Avatar
Question EGR removal or block off
What kind of negative effects, if any, would I have by removing or blocking the EGR after the valve on my 99 5.3L? Is there anything I can do at home with little or no cost to boost performance on my truck?
Old Jun 2, 2005 | 11:02 AM
TheChronic's Avatar
For little or no cost, some people believe that the EGR tube that sticks into the throttle body is an obstruction and trim it down so it is out of the way. You just unhook it from the tb and cut some off. If you pull your EGR completely, you will need to get a tuner to remove the EGR from your computer or else you will have emissions codes.
Old Feb 23, 2006 | 12:01 PM
TX_Z71's Avatar
I cut the tube. After seeing the tube; I don't think it's enough of an obstuction to make even a slight difference but I did it anyway.
Old Feb 23, 2006 | 12:24 PM
stone150's Avatar
what is the advantage of removing the egr other than having one less thing to break?
Old Feb 24, 2006 | 07:35 PM
9GMC9's Avatar
I would also like to know.
Old Feb 25, 2006 | 09:25 AM
WhiteChevy3's Avatar
https://www.performancetrucks.net/fo...ght=egr+delete
kalikid06
20
Oct 13, 2015 07:37 AM
Velocity1
Oct 12, 2015 10:39 PM
SlvrSierra4.8
Oct 1, 2015 09:39 PM
69z-28
Sep 21, 2015 07:31 AM
Pimpinpete
Sep 8, 2015 07:39 PM
