EGR Mod q's....
Old Jul 15, 2003 | 04:06 PM
Hit Man X's Avatar
Default EGR Mod q's....
Okay I hacked that tube running into the intake and now have a quick question about the block off plate...
How large of a hole should I begin with inorder not to set an SES light?
Thanks!
Old Jul 15, 2003 | 04:22 PM
Yelo's Avatar
Default Re: EGR Mod q's....
I think it's like 1/8th or 3/16th....no smaller
Old Jul 15, 2003 | 04:48 PM
Hit Man X's Avatar
Excellent! Thanks.
Old Jul 16, 2003 | 01:26 AM
CashDudeHomie's Avatar
Where do you get that sheet gasket stuff? Did you just cut a 1/8 hole in the gasket itself or did you use a metal plate and 2 pieces of gasket?
Old Jul 16, 2003 | 11:33 AM
Hit Man X's Avatar
I used a metal plate between that gasket stuff. I picked it up at O'Reilly and any auto parts store should carry that gasket stuff.
The 1/8" hole was too small and threw an SES light last night. I drilled the hole to 3/16" and heopefully it will be okay.
Does anyone know if the light will reset itself I do I need to go clear it with AutoTap?
Old Jul 16, 2003 | 11:41 AM
BigKID's Avatar
If the second hole is big enough and the pcm deems everything OK it will eventually clear itself after so many cycles. But since you have atap I would go ahead and clear it.
btw.. a buddy had to go to a 5/32 in his.
Old Jul 16, 2003 | 01:14 PM
YUKONTURTLE's Avatar
Do you know what the DTC code was? I would reset the code instead of waiting for it to clear.
Old Jul 16, 2003 | 01:34 PM
Hit Man X's Avatar
I just went ahead and disconnected the batt as I can't get my damn USB->Serial adapter to work with this damn laptop from work! I guess it is too new.
I need to get an old cheapass laptop for DTC and EDIT.
Any ideas on how long it takes to reset after the batt is disconnected?
Old Jul 16, 2003 | 01:38 PM
1BADHD's Avatar
Couple minutes. I thought you had to pull a fuse or two also.
Old Jul 16, 2003 | 01:50 PM
Hit Man X's Avatar
Well damn I hope I don't have to pull any fuses! lol.
Well, we shall see after lunch here hopefully all will be okay otherwise I will have to tote my desktop out to the garage and clear it!
