ECT how hot is TOOOO hot????
Old Jul 1, 2009 | 06:39 PM
BlackGMC's Avatar
Resident Retard
Default ECT how hot is TOOOO hot????
Well my truck has been running alot hotter in the 100*+ temps... But it is wierd... It will sit and idle all day long with the AC on high and run at 200* basically where the fans regulate it. While driving down the highway it runs at 197* which is also fine. Now if i am in stop and go traffic it will get to 215-220. Today on the way home I was beating on it to see how hot it would get, well when i pulled into my drive it was 224*.... So i left it running in park in my driveway and the temps came back down to 200*....
So i tried pulling some timing, basically adding more the ECT and IAT tables, that helped a little bit but it still gets hot in slow driving... I have a 28" rad with homemade efans (12 and 14) with a shroud... So i am just thinking about ordering some 05 efans and 34 radiator...
Any opinions?
Old Jul 1, 2009 | 06:42 PM
A Low Dime's Avatar
13 Second Truck Club
Same thing happens in my truck. I can sit in a 100* parking lot for 1 solid hour idling with A/C on high and temperature not climb over 190 but stop and go it will climb to 205-210
Old Jul 1, 2009 | 06:44 PM
2007chevy5.3l's Avatar
Try the 05 efans and radiator and go from there if you still have problems. Just my opinion
Old Jul 1, 2009 | 06:47 PM
BlackGMC's Avatar
Resident Retard
Oh and it is not the verter causing it because i bypassed the radiator. But i am thinking that big *** 40k cooler sitting right in front with 160-180* fluid following threw it is not helping the situation either...
Old Jul 1, 2009 | 06:48 PM
00ChevyScott's Avatar
Wearin' da big hat
I don't think anything under 230 is serious.
Old Jul 1, 2009 | 06:50 PM
BlackGMC's Avatar
Resident Retard
Kinda what i was thinking, i was still shifting at 6700 and it was pulling just as hard as it usually does...
Old Jul 1, 2009 | 06:54 PM
I was thinking the same when i put on my 40k. After driving around in 100+ deg heat the engine temp wont go up. But my fans do push alott of air lol
thunder550's Avatar
High on diesel fumes
You have a stock thermostat? I had a 160 and a 180 and during the summer my truck would try to overheat on me all the time (with 34" radiator, and with both factory e-fans and a factory clutch fan). As soon as I went back to stock it's all fixed. I think the coolant was not spending enough time in the radiator to cool down properly.
Old Jul 1, 2009 | 06:57 PM
BlackGMC's Avatar
Resident Retard
yep stock thremo
Old Jul 1, 2009 | 07:00 PM
KySilverado's Avatar
The PCM will tell you when its to hot. DING DING DING... and if you ignore it you'll soon be in limp mode.
