Eaton Q's
Old Jan 27, 2004 | 03:29 PM
KeukaZ71's Avatar
Default Eaton Q's
for some reason i thought i read that Eaton Posi doesn't work at speeds greater than 20 MPH. mine seems to work all the time. i have been breaking the tires loose at 40-50 in 2nd gear due to the wet roads but my rear end fishtails like crazy. it never used to fishtail like that with the open differential. so this makes me believe that the posi it working at greater speeds. what is the real answer
Old Jan 27, 2004 | 03:43 PM
L-EATER's Avatar
11 Second Truck Club
The stock g80 type unit is the one that unlocks. The aftermarket Eaton is full time posi!
Old Jan 27, 2004 | 03:50 PM
onyx's Avatar
14 Second Truck Club
mine works at all speeds too.... dont know whats up with what you read....
Old Jan 27, 2004 | 03:52 PM
abbo7's Avatar
How would the eaton hold up with 500 rwhp through it? Is it capable, or would you need to switch to something better, maybe a bigger rear end all together?
Old Jan 27, 2004 | 04:06 PM
KeukaZ71's Avatar
i thought it was just the G80 that did that. thanks for confirming
Old Jan 28, 2004 | 01:41 AM
Well there are a couple of guys here with a stock rear end, and just an eaton, that are running in the 12's with 500hp or more, with no problems that I have heard from them.
Old Jan 28, 2004 | 08:35 AM
getsome's Avatar
I think parish was running around 600 or so on his old truck with stock rearend and eaton. They are pretty tough.
Go5.3tt06
25
Sep 4, 2016 10:25 AM
moregrip
Jul 26, 2016 11:21 AM
Turk55
Sep 11, 2015 11:52 AM
ArticGMC
Jul 8, 2003 01:04 AM
1TRUESS
Feb 14, 2003 02:52 PM
