E-fans vs clutch fan are they worth it 5.3 rcsb silverado
Old Jan 24, 2014 | 06:29 PM
Chevyboy203's Avatar
Default E-fans vs clutch fan are they worth it 5.3 rcsb silverado
ok im over budget big time with not buying a used stall for my truck but e fans guy wants $400 for rad+fans installed idk
what is the real rwhp on these things all jokes aside for 1-2% not worth it
pushing 420hp on my 5.3 so gaining little as 4-8hp but some guys are claiming 30hp at dyno please help
Old Jan 24, 2014 | 07:15 PM
RezinTexas's Avatar
I don't think its an appreciable HP gain, I did it for the massive difference it makes with the cold AC when idling in HOT Houston traffic.
$400 seems like a great price, if that includes everything. Here is what I paid for my system (installed by me):
$177: New OEM (Dorman) fan assembly for '05 Tahoe
$131: Nelson Harness
$60: Blackbear tune (in-person)
34" radiator = free (already included in my truck)
After the efan swap, my Alternator didn't last long, so that was additional cost:
$160: 145A Alternator
$36: ASP overdrive pulley
Old Jan 24, 2014 | 07:40 PM
TX Tahoe Z71's Avatar
That's about all I got out of it too. No hp or mpg gain, and I track my gas mileage like a crazy person.
Old Jan 24, 2014 | 07:55 PM
Matt C.'s Avatar
Rez, did you have to change the serp. belt size when you put the alt. overdrive pulley on. I have an overdrive pulley from a previous truck, but I just put belts on the truck about 2 weeks ago. I'm going to do LS1 fans in the near future.
Thanks and sorry for threadjacking,
Matt
Old Jan 24, 2014 | 08:33 PM
BlackGMC's Avatar
Resident Retard
I dont think it is worth it for the HP gain. It is definitely worth to not hear the stock fan all the time and the freed up space is also worth it.
Old Jan 24, 2014 | 09:05 PM
GMCtrk's Avatar
The only reason I am upgrading to Efans is because I can't fit my turbo coldside with the 34" radiator. I need the added cooling capacity.
When I had ls1 efans in the past there was no appreciable power gain
Old Jan 25, 2014 | 06:07 AM
RezinTexas's Avatar
Matt
I did not change the belt size.
Old Jan 26, 2014 | 10:22 AM
when u did the change any problems with the alternator ?
Old Jan 26, 2014 | 11:08 AM
I have the 145amp alternator from the factory (over the 105 amp in the pickups, I believe). I have not had any problems with it powering my stereo (two PPI amps, totaling about 350 watts rms) and efans. You could probably pick up a 145amp alternator for less than $75 on ebay or at a pick-a-part and swap it out.
Old Jan 28, 2014 | 09:32 AM
Blwn99x's Avatar
its worth 8-12 hp and the same in torque, definately noticeable in my old 3000 lb s-10 but in a 4000-5000 lb truck, eh.however like stated by others cant hear it like the clutch fan and it frees up room in front of the motor. plus if you are like me and have the 28" core radiator, you will appreciate the larger 34" cooling capacity as you increase hp, especially in hot summers
ferrellrooster
Mar 6, 2025 03:22 PM
ARC
57
Feb 21, 2022 10:54 AM
Ketis
Jul 23, 2015 12:37 PM
rojeho
Jul 12, 2015 06:10 PM
ALynch
Jul 6, 2015 09:49 AM
