E-Fans SUCK!
Old Mar 22, 2011 | 09:21 PM
  #61
dmelvin's Avatar
Originally Posted by Atomic
You could use female spade connectors if you really wanted to.
This is what I did with mine, and heat shrink wrapped all of them
Old Mar 23, 2011 | 12:14 AM
  #62
bobfig's Avatar
Originally Posted by marovetsm
Where did you guys get the socket connectors for the relays at? Ive seen some pigtails but they all have 14ga leads. I would rather get a bare connector w/terminals so I could use my 12ga wire. Or does it really matter that much since I would only have about 4in of 14ga coming out of the relay before it gets connected to my 12?
it shouldn't matter. i have been using 2 of these to run my ls1 fans for the last 10 months and the only problem i have had was a relay decided to crap out on me.
http://www.jegs.com/i/Derale/259/167...oductId=758411
Old Mar 23, 2011 | 12:26 AM
  #63
Blown06's Avatar
8 Second Truck Club
Originally Posted by SnakeOiler
As it shows in the schematic that Atomic's posted, the factory harness has 40 amp fuses
If I'm looking at that picture correctly there is only one 40 amp fuse for both fan circuits. That tells me that two 30's would be plenty capacity. No?
Old Mar 23, 2011 | 06:01 AM
  #64
SnakeOiler's Avatar
Not sure why there is only one fuse shown in that schematic. the schematic I have and factory harness has two 40 amp fuses - one for each fan.
This is the '05+ factory setup.
Old Mar 23, 2011 | 10:44 AM
  #65
48548's Avatar
Originally Posted by gs7793
im so glad my truck came with efans
My truck is an 05 L33 engine 4x4, and I have never had a problem with my factory e-fans and that was one of the first years for them. They work great and keep my truck cool when needed.
Old Mar 23, 2011 | 11:20 AM
  #66
marovetsm's Avatar
Anyone happen to know the part number of the terminals that go into the PCM?
EDIT: Nevermind, found them.
Delphi 12084912 Terminal Female Micro-Pack 100W Gold Plated Terminal, Cable Range 1.00 - 0.75 mm2
Also if anyone didnt already know the cooling fan connectors are Metri-Pack 630's...
Old Mar 23, 2011 | 11:31 AM
  #67
dmelvin's Avatar
From what I've been running, a single 40 amp fuse has been fine. If you're going to run 2 30A fuses, you're going to run at least 8ga wire, because if something shorts out, and you're not using at least 8ga... you're most likely going to have a fire, I don't know if 10 ga. shorted would be able to draw the 60A to blow both fuses.
Old Mar 25, 2011 | 01:27 PM
  #68
marovetsm's Avatar
2 30 amp fuses would be fine because each fan runs on its own circuit, so if you short 1 fan it will only blow 1 of the fuses and the other will be unaffected. You would have to short both circuits independently to blow both fuses.
I'm thinking of using a 30 amp fuse on each circuit because 12 ga wire is only rated to 30 amp and if you have a single 40 amp fuse feeding both circuits and have a short in either of them it will have to blow the single 40 amp fuse which is more than most 12 ga wire can safely support.
The stock 05 schematic uses 2 30 amps fuses (as shown below) instead of the single 40. Will both ways work? Obviously yes, but since Im making mine from scratch I'm steering towards dual fuses. But to each his own.
Old Mar 25, 2011 | 01:31 PM
  #69
dmelvin's Avatar
I thought he was talking about bonding the 2 30A fuses... my bad.
Old Mar 25, 2011 | 01:39 PM
  #70
marovetsm's Avatar
Anyone know where I could get my pcm tuned for efan at a decent price? Im getting my truck re-tuned for E85 in about 6 weeks so I dont wanna pay like $50 for a efan only tune right now, Ill just run a switch till then. I sent wait4me a message but he never got back, I heard he used to do it for the cost of return shipping.
