E-fans
Old Oct 24, 2005 | 10:11 PM
SBChvy's Avatar
Default E-fans
I am looked to install some electric fans on my truck. What do you guys think is the best setup? Is there really that big of a difference? Thanks for the help.
Old Oct 24, 2005 | 10:19 PM
SnakeOiler's Avatar
It basically comes down to visual appeal and budget.
boomers03gmc's Avatar
hum i live in phoenix AZ so YES i think they helped me a lot in the summer!. no more stupid clutch fan. i got a set of 2002 z28 ls1 e fans. and i got the nelson harness. i was very happy with his harness. and i have hptuners to run them.
here are some pics
Old Oct 24, 2005 | 10:28 PM
SBChvy's Avatar
so i need a tune to make them run?
Old Oct 24, 2005 | 10:33 PM
u dont NEED to but thats the best way IMO. u can get an external relay that turns them on when your radiator get warm enough. they come with a lil probe that u place on your radiator.
i dont remember who make them tho.
Old Oct 24, 2005 | 10:40 PM
SBChvy's Avatar
well a tune seems like the best/cleanest/most reliable way. I guess ill get a tune before hand. It has more benifits anyway. Boomers, how do you like your HPtuner? Is it hard to use, and how do you see what results you are receiving? thanks for the results
Old Oct 25, 2005 | 05:45 AM
TXsilverado's Avatar
talk to allen nelson. he can send you a wiring harness along with a custom tune. a good tune will do WAY more than any electric fans.
Old Oct 25, 2005 | 07:11 AM
budhayes3's Avatar
PT's Slowest Truck
Here's a few shots of my 05 efans for ya. It's a little more pricey since you have to use a 34" radiator for fitment, but you also get the benefit of the increased cooling capacity of the larger rad. Combined with the Nelson harness the setup appears factory.
Old Oct 25, 2005 | 10:32 AM
SBChvy's Avatar
they look clean budhayes, how much were they, and how did you turn them on? Did you install a bigger alternator with them?
Old Oct 25, 2005 | 12:17 PM
budhayes3's Avatar
PT's Slowest Truck
Thanks SBChvy. I got the fans for about $200 plus shipping from G&R Auto Parts (new take-offs), already had the PCM tuned by PCMforLess so I just had them update my tune to accomodate for the fans, got the Nelson harness, and got a new radiator from the Radiator Barn for around $260ish. I actually did the larger alternator prior to the efan install, but it's not necessary. tdrumm is running the same efan setup with the factory 105 amp alt. (I got the alternator from G&R also...can't provide a direct link because they aren't a sponsor)
