E-fans
Yea haha I'm doing the same setup as budhayes here. I can tell you this. It will cost at least 800 bucks to got the 2005 fans route...I happened to get my 05 fans brand new on ebay for only 120...but the you need the 34 radiator, 250, the harness, $100 frm nelson, and the tune about 400 from nelson (may as well get the whole damn tune if your going to get it, I mean i dont think he would charge any diff just to tune pin #42 for the fans to turn on)...yea and you eventually need the alternator... sometimes i wonder if its REALLY worth it...
E-fans in general are a nice upgrade that can be obtained on a few different price levels. I really like that I can optimize my 160* t-stat through e-fan control and having the PCM tuned accordingly, but that can be obtained with less expensive LS1 fans or Flex-a-Lite aftermarket e-fans also. (FWIW, my fans are set to come on at 180* and off at 173*)
get some ls1 fans and def get a nelson harness and nelson tune heres some pics of my ls1 fans and nelson harness notice how clean looking the harness is i got the ls1fans from transamcreations its an ebay store and tyhey were like 130 and they weork great and my alt works fine if u get the 05 fans ull need bigger alt.. ls1 fans imo
http://www.cardomain.com/member_page...79_29_full.jpg
http://www.cardomain.com/member_page...79_30_full.jpg
http://www.cardomain.com/member_page...79_28_full.jpg
http://www.cardomain.com/member_page...79_31_full.jpg
http://www.cardomain.com/member_page...79_32_full.jpg
http://www.cardomain.com/member_page...79_33_full.jpg
http://www.cardomain.com/member_page...79_34_full.jpg
Thanks SBChvy. I got the fans for about $200 plus shipping from G&R Auto Parts (new take-offs), already had the PCM tuned by PCMforLess so I just had them update my tune to accomodate for the fans, got the Nelson harness, and got a new radiator from the Radiator Barn for around $260ish. I actually did the larger alternator prior to the efan install, but it's not necessary. tdrumm is running the same efan setup with the factory 105 amp alt. (I got the alternator from G&R also...can't provide a direct link because they aren't a sponsor)
Looking at METALMULISHA777's pics just reminded me of another note...if you do go the 05 e-fan route and have a K&N FIPK for a 1500, the heat shield will need to be modified to clear the radiator. The spot where the heat shield bolts to the rad support is the same spot where the 34" rad bolts in. Not sure which other CAI's need modification, but I do know that the Volant clears with no problem, and I'm pretty sure that a K&N for a HD will work also.
Think ill be going the ls1 fan route, with a nelson harness, and tune. You don't need a 34" radiator with the ls1 fans right? When he tunes, does he put it on the tow haul mode, or just a differnt set of shift points there? Thanks for all the help guys, this thread has been very helpful.
Originally Posted by brodystruck
Did you do anything to mount the fans on the bottom side... I haven't really looked at my fans (unmounted LS1 take offs) or my truck closely...
