E-fan Harness?
Old Jun 13, 2005 | 12:58 PM
OCBC's Avatar
Default E-fan Harness?
Picked up some lt1 fans, now I am looking for a harness. I know that nelson makes one and is highly recommended by most people here. My question is will the nelson harness work with a tune from a different shop? (pcmforless tune with the fans turned on) From what I have read, it should, just want to make sure. Also, is anyone using the pcmforless harness? any real difference than nelson? I know its about the same price.
Old Jun 13, 2005 | 01:05 PM
Dub Silverado's Avatar
Im pretty sure the nelson harness will work with any tune. Best thing to do is just give him a call real quick and ask....
Old Jun 13, 2005 | 01:09 PM
budhayes3's Avatar
PT's Slowest Truck
I have the PCMforLess tune with a Nelson harness, it works great. Basically, the different tuners all do the same thing, ground pin 42 to turn the fans on and remove ground to turn them off at whatever temps they're set for. The PCMforLess harness and Nelson harnesses are totally different in the way they're designed, plus the PCMFL harness doesn't have a provision to turn on the fan for a/c. Personally, I'm very impressed with my tune and harness...they work well together.
Old Jun 13, 2005 | 04:20 PM
OCBC's Avatar
well, that is good to know. I will be looking into the nelson harness. Cant wait!
Thanks guys.
Old Jun 13, 2005 | 10:26 PM
ChevyMan23's Avatar
Im wanting the Efans..if I buy the 05 GM fans..will I need a harness?...or will it come w/ one?
Old Jun 14, 2005 | 12:16 AM
Flyer's Avatar
You will need a harness.
From what I can tell, both harnesses are the same, the 3 relay harness that is. They are both made from the same wiring schematic I *think*. Sometimes thinking gets me in trouble though.
Either harness will work with any tune. Just as long as the PCM is told to turn the fans on and off and the harness is installed correctly.
There is another harness available, that has an adjustable low speed setting triggered by temp and AC, high speed being triggered by the PCM. I'm not quite at liberty to discuss many more details, but you can PM me about it.
Old Jun 14, 2005 | 12:21 AM
vanillagorilla's Avatar
I'll discuss it too, if you want to PM me.
Wrecker 426
Sep 30, 2015 09:39 PM
Silver8ado
Sep 30, 2015 11:42 AM
StrokeTheLS
Sep 29, 2015 08:33 PM
old motorhead
Sep 29, 2015 08:22 PM
97gmc
22
Sep 8, 2015 10:56 PM
