Dynomax "X-pipe" Mufflers?
Old Mar 8, 2011 | 02:48 PM
White2500's Avatar
Default Dynomax "X-pipe" Mufflers?
http://www.summitracing.com/parts/WLK-17553/
Gonna use this muffler for my custom exhaust build. Any reasons not to?
Old Mar 8, 2011 | 05:23 PM
White2500's Avatar
Any experience with this or the similar style Magnaflow?
Old Mar 8, 2011 | 08:50 PM
PathfinderJr's Avatar
In my opinion, the x-pipe in the muffler is little more than marketing hype. By the time the exhaust gases reach the muffler in a standard position on the truck, the gases have cooled enough that their velocity through the x-pipe is slow enough to not help "pull" the exhaust through the other bank via the cross-over.
Any cross-over pipe, be it an x-pipe or an h-pipe, needs to be as close to the collectors as possible to be of most benefit. The reasoning is because that is where the exhaust gases are of a higher temperature and don't move lazily like they do when it cools down.
So in short, I'd ditch the x-pipe in the muffler and get a true x-pipe and put it as far up in the exhaust as you can.
Old Mar 8, 2011 | 09:47 PM
pewterliftedz's Avatar
i ran the magnaflow X in my truck, idk if it actually has the same effect of a X midpipe. It sounded dam good on my old truck.
Old Mar 8, 2011 | 10:16 PM
White2500's Avatar
So from a performance standpoint, the "x" mufflers are pointless. Maybe a di/do magnaflow without the x or two single straight through style mufflers with an actual x pipe after the headers? my main concern being that I'm building my own exhaust and didn't buy an x pipe or anything. I guess that will be on my "to make" list. Catch my project in the projects section. Planning to start on Thursday.
Old Mar 8, 2011 | 11:53 PM
If you're running duals, I'd highly recommend an x-pipe, or just any crossover pipe. It'll help the exhaust scavenging, especially in the lower rpm range.
Old Mar 9, 2011 | 12:15 AM
White2500's Avatar
Alright so an x pipe it is.
Old Mar 11, 2011 | 12:43 PM
Dynomax Exhaust's Avatar
FormerVendor
Talking
Don't forget about our 90 day risk free offer.
http://www.dynomax.com/safeandsound.php
'02SOMz28
Nov 2, 2015 05:47 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
Rockrz
Sep 29, 2015 09:07 AM
FlowmasterMufflers
Sep 18, 2015 02:31 PM
