Dynojet Dyno
Old May 18, 2005 | 11:01 AM
moregrip's Avatar
what a rush!
Default Dynojet Dyno
I've had about 10 or so pulls on a dynojet and they use the WinPEP software to evaluate the data.
Here's the question, all of mine have been smoothed 5, it is adjustable form 1-5, "smoothing" is what its called. I can see that it allows for a less erratic line, is there any other purpose? and what is the standard?
Old May 18, 2005 | 01:37 PM
jimbob's Avatar
11 Second Club
"Grippy"
The smoothing is just that.... just gets rid of the peaks and valleys (up to a point) to give you a more accurate (average) reading. I prefer 5 for smoothing, some people like 1 as it usually gives an inflated peak number that the power band can't substain. The average is 3 to 5 that I see, I have a stack of maybe a hundred to choose from so.....
Jimbob
Old May 18, 2005 | 02:06 PM
moregrip's Avatar
what a rush!
Originally Posted by jimbob
"Grippy"
Jimbob
Thanks Jimbob, I just wanted to make sure I understood that correctly and completely
Old May 18, 2005 | 06:59 PM
BlownChevy's Avatar
blownerator
25 Year Member
Who would smooth it to 1???
Old May 19, 2005 | 04:11 AM
jimbob's Avatar
11 Second Club
The same ones that STD correct instead of SAE correct. Seen it way too many times ......Goes something like "My numbers are so and so"...."Guys on net," cool man your pushing some serious numbers, more than I have ever seen. Turns out they smooth to 1 (just to say they had smoothing on), STD corrected (just to say they were corrected numbers, adds about 5 percent to the rear numbers) pull the belt, ice the intake (LT1 style), pump the air pressure in the back tires, run race fuel (on engines that generaly don't need it, except for a few more hp), light weight tires and rims, run the AFR way to lean (only for dyno), same for timing, uncorked headers...blah, blah...blah.
Some of these are practices you might do on a strip....but on the street that's another story. These practices were more to do with posting the highest dyno numbers, and I'd seen way to many post saying I'm only getting this Crwhp. Other guys jump on saying yeah so and so makes this, something is wrong with your combo. So, they would either stay around and suck up there supposidly low numbers or worse, sell off there combos and never to be seen again. I got tired of posting, trying to help these kids with there combos explaining where their horse power in gone too, there got to be more negative posting than I could help overcome with good info. Anyway, that was years back on CZ when way to many people were just worried about dyno queens instead of actually racing them..I moved on...(well, ok I still go to the advanced section) still see it once in a while here but not much....That is why I joined/followed the big racers on this site years ago when they came over from LS1....This is the best site overall that I'v been on...
.....and the award for best "Suck Up" goes too.......
Next dumb question.......... hehehehehehehe
Jimbob
Old May 19, 2005 | 01:19 PM
BlownChevy's Avatar
blownerator
25 Year Member
jimbob, your answer is exactly why I asked the question.
Old May 19, 2005 | 02:13 PM
jimbob's Avatar
11 Second Club
Yeah that got to be a bad time for newbies back then. One or two guys would say good numbers....then 10 guys would jump on saying that sucks....on the same post. I use Dynojet/mustang numbers only for comparison of previous combos. It's especialy true with converter auto trannys.....may dyno low, but have one hell of an average hp level The good thing around here is that I'v dynoed at 4 different Dynojets and I would say that all were within 4 hp of each other (damn accurate) for testing and tuning combos.
Jimbob
$A_Money$81
Mar 27, 2023 10:25 AM
Go5.3tt06
25
Sep 4, 2016 10:25 AM
Lthompson
Oct 2, 2015 12:45 AM
jscherbs
Sep 30, 2015 07:54 AM
norris_83
Sep 9, 2015 04:14 PM
