Dyno'd after the 4l80e swap
Old Oct 24, 2004 | 11:31 PM
  #21
Green Thunder's Avatar
nice numbers but i think you may be premature blaming the EX springs for you top end miss. i did the same thing, missing above 6k, then 5600, then 5200, thought it was the springs so i swaped in some patriots and it didn't fix it. turns out it was an ignition issue for me.
Parish what was your ignition problem?
GMC SKI May sound like a stupid reply but what is your spark plug gap? Try narrowing it a bit... May sound crazy but fixed my high RPM miss... Extra boost needed smaller gap.. Just a thought..
Parish what plugs and gap do you run?
Old Oct 24, 2004 | 11:35 PM
  #22
GMC SKI's Avatar
My plug gap is .55 is that too big ?
Old Oct 24, 2004 | 11:36 PM
  #23
parish8's Avatar
single digit dreamer
i am running ngk br7ef plugs at the gap they come out of the box, i think it is .025.
i am 99% sure my top end mis is caused by lead fouling of the plugs. i a running leaded fuel and there is some info out there about the subject. to fix it i run new plugs before any event. they seem to last at least 1000miles on the street but need to be prety fresh if i am going to open the exhaust and crank the boost. it may not be lead related but some other plug problem but new plugs seem to fix the problem.
Old Oct 24, 2004 | 11:37 PM
  #24
parish8's Avatar
did you mean .35? .55 is huge for what you are doing.
Old Oct 24, 2004 | 11:44 PM
  #25
GMC SKI's Avatar
I meant .65 .... really no I'm at .35 Seems to work well for me at the power level I'm at right now Never had the issues dyno three times before with the same gap
made near the same power with a flat HP and TQ curve
So i'm gonna try out a new set of springs
I have about 10k on the current ones that are rated to stand up to a .620 lift the cam is at .600 so i think they may be a little tired
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
XL7
May 5, 2022 01:48 PM
lycominghunter
Jul 29, 2015 04:24 PM
alex226
Jul 16, 2015 10:55 AM
NuckenFuts
Jul 9, 2015 08:45 AM
