Dyno results from LS1
Old Mar 11, 2003 | 04:48 PM
11 Second Club
Default Dyno results from LS1
LS1 with under drive pulley, CIA, LS1 Edit, 2400 converter, 3.73.baro pressure-29.07, humidity 90%. STDMax power=309.9 STDMax Torque=335.2. SAEMax power=303.6 SAEMax Torque=316
Uncorrected Power 297 Uncorrected Torque 309.
I have the Print out for the STD, but SAE and uncorrected is going by memory. Im sure with good air I would make over 300 uncorrected. I should also note that that was through stock exhaust.
Old Mar 11, 2003 | 04:56 PM
XLR8NSS's Avatar
Adkoonerstrator
Default Re: Dyno results from LS1
That's some nice power and I bet the truck feels better with that 80lbs off the frontend. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
How's that extra torque feel just cruising around? <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
John
Old Mar 11, 2003 | 05:14 PM
11 Second Club
At first I wasn't sure there was much of a difference, but after running another ex cab 5.3 I knew there was alot more there. Not sure what his mods were, but I put about 10 bus links on him by the top of second. It will be fun seeing how much power I can make with cam heads and exhaust. I am also going to beef up the trans next week. Yes the torque is very noticeable. Hopefully I will have some times with this setup to compare with future mods.
Old Mar 11, 2003 | 09:31 PM
FarmTruc's Avatar
Performance Trucks Sponsor
You know I had to chime in, hahaha <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
With all that power i still whooped you, lol
j/k, for those wanting the ls1 over the 5.3 and 4.8, it's a good upgrade, better than putting all that money into cam, pulley, headers, junk, etc.
btw, the stock 5.3 pcm/code will run the ls1 just fine, a little bit of tuning will need to be made on idle, but it's very acceptable and i was very suprised how well it ran.
later,
allen
Old Mar 11, 2003 | 09:33 PM
StupidFast's Avatar
Did the LS1 drop right in? I heard that some of the bolt holes don't line up. I will need this information for future use. Nice numbers. Thank you.
Old Mar 11, 2003 | 11:07 PM
GoldenVelvet's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by FarmTruc:
<strong> for those wanting the ls1 over the 5.3 and 4.8, it's a good upgrade, better than putting all that money into cam, pulley, headers, junk, etc.
</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">The best part of the swap you can still do the cam, pulley, headers, ect.
P.S. How close is the programing for the 4.8 and 5.3??
Old Mar 12, 2003 | 01:38 AM
Ryan23silverado's Avatar
I need to know about tuning issues with the LS1 swap too. You can just use all of the 5.3L engine harness and computer PCM to control the LS1, correct? I have LS1edit, so new spark tables and stuff should be no problem. What did you guys do as far as fuel injectors...just keep the stock ones? I have a '99 and the injectors are smaller than '00 trucks. Do you think these would have to be replaced?
Thanks,
Ryan
Old Mar 12, 2003 | 05:49 AM
ts99's Avatar
I have a 99 ECSB Sierra that I have installed a LS1 in. It triggered a SES light and is rich on one of the banks.
I used the LS1 injectors but the truck intake and PCM.The only mods is a UPD lid, Shaner throttle boby and Magna flow exhaust
I have purchased LS1edit and EASE diagnostics. I have not had the time to start tuning.
I read the posts in the PCM section but they are mainly for F Bodies.
Where do I start with the tuning process.
Thanks,
ts99
Old Mar 12, 2003 | 09:14 AM
11 Second Club
If anybody wants I can send a copy of my file. With the exception of the IAC adjustment my program runs great, and never any SES problems from the first start up.
Old Mar 12, 2003 | 09:32 AM
Just curious. Has anybody dropped the 8.1L in a 1500 series truck?
