Dyno Results
Old Jan 22, 2005 | 05:05 PM
davew72's Avatar
Default Dyno Results
Well went to the dyno today, I must say I am pleased with the results.
with stock pcm 246.23 rwhp 299.74 rwtq
with custom tuned pcm 273.38 rwhp 335.06 rwtq
gain over stock 27.15 rwhp 35.32 rwtq
If you figure 26 percent driveline loss with the allison tranny
stock 246.23 rwhp + 26% = 332.74 at the crank
westers 273.38 rwhp + 26% = 369.43 at the crank
h.p. gain at the crank 36.69 not to bad
The only other mod done on the truck performance wise is an airaid filter kit
stock pcm Dyno sheet
Custom tuned pcm Dyno Sheet
as you can see on the stock dyno run the torque had a bad spike so I did not use the toque from that pull
The custom tuned pcm had approx. 750 miles on it when dynoed
I pulled it in dynoed it with the westers two pulls then swapped out the pcm's and did two pulls on the stock pcm.
93 hot tune Westers
$A_Money$81
Mar 27, 2023 10:25 AM
Go5.3tt06
25
Sep 4, 2016 10:25 AM
Lthompson
Oct 2, 2015 12:45 AM
jscherbs
Sep 30, 2015 07:54 AM
norris_83
Sep 9, 2015 04:14 PM
