Dyno numbers.....S!@#$%
Old Mar 14, 2009 | 10:33 AM
1_Blwn_sierra's Avatar
Registered User
Default Dyno numbers.....S!@#$%
On 8.5lbs of boost.... @4979rpm 283 lbs tq 250hp 14.9 AFR timing advanced to 29!!!!!!! Er I think I have an issue!
Old Mar 14, 2009 | 10:34 AM
foggy's Avatar
sounds like you need to get a tune before you blow that engine.
Old Mar 14, 2009 | 10:38 AM
05GTO6SPEED's Avatar
um somthing is wrong
Old Mar 14, 2009 | 10:41 AM
Registered User
I have the whipple charger with the aux injectors and the whipple injection box....42lb injectors should help I think. But what do I do with the injection box?
sickREDsierra's Avatar
SHUT IT DOWN!!!
thats a recipe for a blown motor.
you need to be low-mid 11's AFR and 20* or less timing to start with. please be careful.
Old Mar 14, 2009 | 10:48 AM
Registered User
I put a brick behind the gas pedal... Cant push down on it no more.
Old Mar 14, 2009 | 10:53 AM
KLUG'S SS's Avatar
FormerVendor
Get rid of those aux. injectors and whatever else that has to do with it, inj. box, etc.. throw it away. Get some 42lb injectors and a good tune should get you going. I have never heard anything positive about using that fuel setup that Whipple gives you.
Old Mar 14, 2009 | 11:53 AM
dirt track racer 81's Avatar
i seen one of those put down close to the same numbers. i wasnt impressed at all
Old Mar 14, 2009 | 12:45 PM
QLF's Avatar
QLF
Wow, those are right at the numbers for a tuned 5.3. That sucks, this is a good example that a improperly tuned and equipped setup can lead to wasted cash and a blown motor with no power really quick. Get that thing running right man, I would hate to see you burn through an engine for no reason.
Old Mar 14, 2009 | 12:47 PM
Atomic's Avatar
I have a gauge for that
I cringed when I read this
