Dynatech Headers + Factory Wires = Trouble
Old May 13, 2005 | 06:46 AM
OLD BULL's Avatar
Earls plumbing sells some insulation tubing that you can run your plug wires through. It's good to 2000deg, your plug wire can literally lay on the primary and be ok.
Old May 13, 2005 | 07:05 AM
KySilverado's Avatar
Thats what I have tried. Maybe not Earl's specifically, can't remember the brand names. Expensive though. The wires won't burn/melt but they will become brittle and break down eventually failing. The last plug wire replacement was during my cam install. The wire was still working (in a boot) but as soon as I touched it to remove it basically snapped in half. Even tying them down I think this will eventually happen. To close to the heat. For #5 and #7 may be a combination of tying down with a heat boot might be the ticket to longevity?
Old May 13, 2005 | 07:16 AM
Originally Posted by moregrip
wonder why they do that one primary like that? are they equal length?
They aren't advertised as equal length/tuned. Don't believe they are. As negative switches stated, believe its just to get over the steering stem. Believe these headers were originally an SLP design but couldn't get them smog legal and sold them off?
Old May 13, 2005 | 02:58 PM
negativeswitches's Avatar
actually ky i have a stock plug wire on the #7 cyl casue i broke one of the taylors so you should be ok on that front
if you look close you can see it in the pic
Old May 13, 2005 | 08:38 PM
99Silver6.0's Avatar
Nobody else does that. Guess they wanted to be Pioneers in their field.
Old May 14, 2005 | 12:04 AM
SnakeOiler's Avatar
Are you using the factory wires with the metal heat shield. Are they the ones for truck. Think I read that vette or LS1 wires are a bit longer.
Yep, stock wires. #5 and #7 currently have MSD tape on them, as well, for a little added protection.
Old May 14, 2005 | 09:02 PM
Seeing Red Again's Avatar
I just loosely zip tied the stock #5 and #7 plug wires to draw them closer together. This moved them away from the headers and has been working for me for about 6 months now.
Old Aug 10, 2005 | 06:26 PM
aklim's Avatar
Here's what snakeoiler did. I remembered thinking how clean and effective it looked when I saw your post:
https://ls1tech.com/forums/showpost....73&postcount=4
Could you show me where it is? Linky no worky. thanx. I am having those issues too and I would like to see his solution. Thanx.
Old Aug 10, 2005 | 08:19 PM
budhayes3's Avatar
PT's Slowest Truck
Darn, I can't seem to find it anymore??? (maybe it got lost in the shuffle from LS1Tech to here??) Maybe try shootin a PM over to Snakeoiler and he can email ya some pics...
Old Aug 10, 2005 | 09:34 PM
SnakeOiler's Avatar
Here's the thread: https://www.performancetrucks.net/fo...d.php?t=212019
thunder550
Oct 8, 2015 04:53 PM
GrooveCityZ71
Aug 31, 2015 12:05 PM
MWRitter
Jul 27, 2015 09:41 AM
