Dumb Question Here
Old Jan 4, 2004 | 05:23 PM
ts99's Avatar
Default Dumb Question Here
Exactly where is the PCM located on a 99 Sierra, and how do you physically get to it?
Also where do the knock sensors go into the PCM?
Pardon my ignorance,
Thanks,
ts99
Old Jan 4, 2004 | 05:26 PM
99Silver6.0's Avatar
Its under the hood. Standing in front of your truck, it is located on the right behind the radiator near the fender. How to get it out, I cat help ya with, sorry. Are you wondering about which wire colors are coming from the knock sensors or where the snesors are?
Old Jan 4, 2004 | 05:30 PM
ts99's Avatar
Where the sensor wires come from and where (what color) do the go into the PCM.
Old Jan 4, 2004 | 05:44 PM
Banned
the knock sensors are under the intake manifold inside the valley cover (kinda)....i'm not sure what color the wires are though.
Old Jan 4, 2004 | 09:31 PM
bigblue4x4's Avatar
Let me guess SES code P0332 knock senser low input.If you pull off the intake cover ontop of your engine,on the drivers side back of the intake theres a 2 wire plug with a light blue and a dark blue,grab a multimeter and set to 200k ohms scale and ground one of the meter leads.Measure the knock sensor resistance it should be between 91k and 110 k ohms.If it is not let us know and I will dig up what to do next.GM has a tsb on the rear knock sensor for corrosion.
Old Jan 5, 2004 | 06:09 AM
ts99's Avatar
Sorry, nos SES codes, but I do have 8* of false knock retard. I am going to put a resistor in each sensor line to de-sensitize the sensors.
I still have not found the PCM and the wires coming from the intake (sensor wires) so I can add the resistor.
Need further direction,
Thanks,
ts99
Old Jan 5, 2004 | 06:16 AM
Banned
email bigtex or parish8 they're modorators here and i know richard has done somthing similar and i think parish did also at one point.
Old Jan 5, 2004 | 07:57 AM
mudz5.3's Avatar
There was just a post on knock box install about 99's having 8* false knock. Look for that thread, couldn't more than a week old. I know the label has Knockbox in it.
JordanH
Dec 25, 2015 08:32 AM
projectnightcrawler
Sep 30, 2015 10:49 PM
spooneralmighty
Sep 11, 2015 02:28 PM
chevstang421
Sep 10, 2015 09:16 AM
carid
Sep 10, 2015 09:07 AM
