DTC code help!
Old Sep 12, 2005 | 11:29 AM
TG02Z71's Avatar
Default DTC code help!
Posted this in tuning but think I should put it here instead.
I did not check for DTCs before I did my injector swap and new PCM Saturday but this is what I'm getting now.
I have a NELSON tuned PCM.
This is how they read exactly off Predator under DTCs not ran section.
I only use Predator for diagnostics.
The truck seems to run fine, I have only put on about 40 miles since the swap Saturday.
Any suggestions?
P0440 (EVAP Control system Malfunction)
P0442 (EVAP Control System (small leak), Leak Detected)
P0446 (EVAP Control System Vent control Circuit Malfunction)
P0741 (TCC Circuit, Performance or Stuck Off)
P1441 (EVAP System Flow During Non-Purge)
Old Sep 12, 2005 | 01:02 PM
BlownChevy's Avatar
blownerator
25 Year Member
Check your gas cap.
Old Sep 12, 2005 | 02:21 PM
TG02Z71's Avatar
Originally Posted by BlownChevy
Check your gas cap.
No problem there.
Thanks.
Old Sep 12, 2005 | 02:25 PM
budhayes3's Avatar
PT's Slowest Truck
Check your gas cap.
Yea, a loose gas cap or any other leak in the EVAP system will throw a code. Be sure to check all of the hoses and connections on the intake also, something may have gotten disconnected during the injector swap. Not sure why you're getting the torque converter lockup code though.
Old Sep 12, 2005 | 03:06 PM
TG02Z71's Avatar
Ya, the converter on is the one that buggs me the most.
I guess a triple check is in order.......going out in the lot now!
Old Sep 12, 2005 | 04:18 PM
TG02Z71's Avatar
The only thing I found was the line from the top center of the manifold to the back of the drivers side valve cover was not fully seated. A very small gat was present. I also pulled off the line going from the fuel regulator to the manifold and put it back on to make sure ot was on tight.
I reset all the DTC's not ran and got 50 DTC's not ran showing up. I guess most will go away after I drive the thing home like they did the other day and hopefully the others will too that were there this morning.
Old Sep 12, 2005 | 05:38 PM
mjgjr72's Avatar
dtc not ran scc (since code cleared)
shows what dtc tests where not performed during the dtc check
means the pcm has not run a performance test during driving cycle since code was last cleared
not a current code don't worry about it inless it shows in all dtc
Old Sep 12, 2005 | 06:18 PM
TG02Z71's Avatar
Thanks again mjgjr72,
I'm still a newb with allot of the tuning and scan lingo.
Pimpinpete
43
Dec 22, 2017 08:13 AM
00loudchevy
Dec 3, 2015 05:54 PM
Avalanche2002
Nov 30, 2015 07:31 AM
bearden86
26
Nov 15, 2015 03:58 PM
creekrat
Sep 10, 2015 12:59 AM
