DrX 90mm TB harness A+++
Just installed it and had no hitches or issues to speak of. It does though, noticed with engine off, at WOT the throttle plate quivers and makes a noise as it does it.
Don't recon it is a problem just wonder if it is normal.
Power difference is VERY noticable. That little TB was choking mine down for sure.
I'd say 20hp+ improvement by the SOTP feel. And that is before tuning. It is obviously hitting different cells cause it is 10:1 at 2500-3500 and slowly leans out in the upper rpm band to 12.4:1 so there is more in it with tuning for sure.
TurboGibbs, that is GREAT news! Thanks for the update. Did you notice your part throttle shifts being off at all? When i did the 90mm conversion and having the TB not open all the way it screwed up my part throttle shifting and my TCC lockup settings. just wondering what your take on it is?
Originally Posted by TurboGibbs
Some just forget sometimes that there is another life in the world of hotrodding. My part throttle and full throttle shift points and firmness change all the time depending on how I feel at the moment.
I hear that this mod is doing well on the 06 trucks too(different TAC module than 03-05). So no pedal swaps required.
Grant
Originally Posted by DrX
A slight twitch of the blade is normal when trying to maintain a specific TP. Stock TB does the same.
Grant
Grant
AHHHHHHHHHH ok, makes sense now lol
smiley for a reason. Not showing how I swap from Park to Drive really fast multiple times like some auto boys do.
