drive by wire swap
Old Jun 13, 2006 | 06:30 PM
seeyaa's Avatar
Default drive by wire swap
hey guys just picked up my lq9 and its drive by wire and my 5.3 is not what do i need to do. also the oil pan is cracked can i just switch that from my 5.3. thanks any ifo would be great.
Old Jun 13, 2006 | 06:40 PM
thunder550's Avatar
High on diesel fumes
Oil pan should swap right over, and just swap your intake off the 5.3 as well. Then your cable throttle body will bolt right up. That's the only difference. Make sure you use your old harness and PCM.
Old Jun 13, 2006 | 06:42 PM
seeyaa's Avatar
hey thanks and while i have the pan off maybe in will put in some arp rod bolts
Old Jun 13, 2006 | 07:02 PM
thunder550's Avatar
Good idea, cheap insurance. That's what I did.
Old Jun 25, 2006 | 12:00 PM
seeyaa's Avatar
why cant i just swap thottle bodies the 5.3 one fits
Old Jun 25, 2006 | 03:34 PM
kbracing96's Avatar
I believe you can, but the DBW intakes don't have the brass inserts pressed in for the throttle cable bracket to bolt to.
ARC
57
Feb 21, 2022 10:54 AM
1slwgto
Aug 16, 2015 06:40 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
Nimoryan
Jul 5, 2015 03:50 PM
