Drilling TB blade for startup and idle
Old Jun 19, 2014 | 07:32 AM
TXsilverado's Avatar
Cracking the tps blade too much can cause issues too.
Heres what i do. Set the blade set screw to where the TPS voltage is within factory spec at 0% throttle(search that voltage i cant remember it off the top of my head). From there, drill the throttle blade until you get an IAC count of 40-80 when the motor is up to temp in park/neutral. This method keeps the PCM happy and the motor happy.
Old Jun 19, 2014 | 09:05 AM
MPFD's Avatar
11 Second Truck Club
Thats a pretty wide margin, and doesn't give your IAC alot of room for adjustment on the top end. But what ever works.
Old Jun 19, 2014 | 10:39 AM
Iac is just there for idle. Why are you worried about it at top end?
Old Jun 19, 2014 | 10:41 AM
nickleahy23's Avatar
I made some adjustments last night and its much better. Turned the set screw in a bit and now i get start up no problem. Just need to adjust the IAC as when im idling it moves the truck, should be a simple adjustment. Just a little fine tuning and it should be good to go. TPS seems to read good as well.
Old Jun 19, 2014 | 10:42 AM
MPFD's Avatar
I meant the top of its range during slow cruise or idle, not high RPM. Mine counts from 0-about 100 and 80-100 isn't much room for making adjustments when it trying to compensate for the throttle blade slamming shut.
Old Jun 19, 2014 | 01:22 PM
gnd111's Avatar
What brand TB is it?
Old Jun 19, 2014 | 02:06 PM
its a Billet 92 mm Nick Williams knock off.
Old Jun 24, 2014 | 11:29 AM
gnd111's Avatar
That's the problem..you may need to drill
Old Jun 24, 2014 | 11:58 AM
i had to drill the **** out of my nick williams 90mm with a fast intake.
Old Jun 24, 2014 | 09:29 PM
NuckenFuts's Avatar
Damn I have the same problems as you right now that justin and I have been going back and forth on. I have a 102MM and every day on start try to adjust Blade to find a sweet spot.
Just sent justin this video the other day as I get this **** too.
https://www.youtube.com/watch?v=pJJs3GbEQ4w
