dont forget to change you exhaust fluid!
#31
11 Second Truck Club
The exhaust temps only have to reach 400 degrees F to allow SCR injection to take place. While I agree that Cats are good for Hydrocarbons, no Cat will lower CO2, where SCR gives us that ability. SCR would allow the death of EGR, almost zero emission's with zero effects to power levels or economy.
#32
I work at NAPA guys and we sell it for $12.19 for 2 1/2 gallons, its valvoline brand and IS compatible with all the specs so dont get ripped at the dealerships.
And i think the ford guys take 5 gallons every 5000 miles but dont hold me too it.
#33
It is just fertilizer, UAN comes in the same concentration, BUT you don't wanna try to use the fertilizer grade stuff cause the urea in it is treated with a polymer additive that allows a slower timed release of the ammonia into the ground and it can hose up dosing control modules. Don't ask me how I know that...
#34
At first I was pissed while reading this because I thought they were adding this on top of the particulate filter. If this is supposed to replace the filter then this could be a great advancement for the diesel industry. The idea of a diesel engine cleaning the air as it operates is awesome.
#35
#38
I think that when people start seeing Re-gen down time and temps vs SCR it will be the only clear option. A re-gen phase is basically using a injector to spray raw fuel into the particulate trap and a glow plug ignites it to burn it out. The problem with this is your exhaust will be at ultra high temps during this re-gen, and your basically brought to a halt during the process. Imagine being in a combine off loading wheat in the middle of a field and it goes into re-gen. Now your stuck there in the middle of a field and your exhaust temps all of a sudden go to 2000 degrees F with the air around you full of wheat dust and crop material, you can't go anywhere cause the combine has no power during a re-gen. Thats not a place I would wanna be with high exhaust temps and an de-mobilized piece of equipment. SCR only needs exhaust temps of 400 degrees F to work and doesn't completely shut you down just de-rates you to 50% power till its refilled. And the usage is so low that you'll have the chance to fill that tank during three prior re-fuelings.
Here is what happens when the software malfunctions.
http://www.youtube.com/watch?v=-dKLKm5i2ic
Awesome Ford!!!!!
Awesome Ford!!!!!
#40
Suburban2500
07-19-2015 04:50 PM
