Done Some Research...Now Some ?
Old Nov 26, 2010 | 04:40 PM
  #21
Tootall's Avatar
Originally Posted by 00_Silverado_Z71
Reluctor on which cam the ls7 or the tsp 220? From what i've been reading it doesnt seem to have many bad reviews as far as the tsp 220? How much do you want for this one and i'll see if I have the funds for it...
The Ls7 has no reluctor wheel/pickup sensor in the rear of the cam like the GEN III motors do (YOUR MOTOR). If you wanted to run that cam, you would have to get the 1.8 rockers, LS2 front timing cover, cam sensor, LS2 timing gear and then extend your harness from the rear to the front of the motor.
The TSP 220 that I have is for GEN III motors . . . just like what you have . . .
You'll need either PAC springs, 918s or PRC duals to run it . . . it's up to you. Hardened 7.4 pushrods, reuse the stock retainers, and locks.
Old Nov 26, 2010 | 04:52 PM
  #22
low_chevy04's Avatar
And what do you want for the TSP 220/220 and i'll see if I have the funds for it.
Old Nov 27, 2010 | 10:06 AM
  #23
Tootall's Avatar
Originally Posted by 00_silverado_z71
and what do you want for the tsp 220/220 and i'll see if i have the funds for it.
$350 . . .
Old Nov 27, 2010 | 11:22 AM
  #24
Not in the budget this paycheck I found someone who has for $150 I think i'm gonna buy.
Old Nov 27, 2010 | 12:12 PM
  #25
JFOLM's Avatar
Don't cut corners.
Old Nov 28, 2010 | 12:08 AM
  #26
A high winding car cam not worth a damm in a lifted 4x truck. They are two completely different beasts with different needs when looking at camshaft selection. Do your homework here and you will be rewarded with great power driveability and gas mileage. **** up and you will have a truck that a KIA can outrun until you get to 2500-3K plus RPM and lousy gas mileage.
Old Nov 28, 2010 | 01:34 AM
  #27
Ok, so i've been told like 10 different things as far as cams and which one to pick...someone give me some knowledgeable info so I can get one picked out and bought. What is a good cam for my truck being a daily driver and also lifted? Seems as if everyone I nearly decide on isn't a good cam...I'm seriously about to say **** on it and not even do one and put the money elsewhere I guess
Old Nov 28, 2010 | 01:57 AM
  #28
grey matter 04's Avatar
13 Second Truck Club
Originally Posted by Tootall
Start looking for a 212/218 .522 .529 -112 or 114
or the Vinci Trucker or the "old man cam"
Those are all great bottom end cams
Ls6 - 01 - 204/211 0.525/0.525 Lsa 116
Ls6 - 02-up - 204/218 0.555/0.551 Lsa 117.5
any of these would be a great choice
No need to over cam a big lifted heavy 4x4 on big tires...why make it more of a slug
And dont cut corners or go for the cheaper parts you will regret it after its built
You want one of the listed cams because they make bottomend torque that you need
Old Nov 28, 2010 | 02:02 AM
  #29
I had originally before I ever posted was deciding on a 02+ ls6 cam since you can usually pick one up decently priced but I was unsure about it. Is a torque converter a must with a ls6 cam or is it something that could be done down the road and would be fine for now since i'm on somewhat of a budget here.
Old Nov 28, 2010 | 02:07 AM
  #30
a stall is not a must but will be helpful with the ls6 cam
I would go 212/218 cam over the LS6 in a 4x4
212/218 is gonna have better lowend torque
