Does Valve lift affect power band?
From what I have seen so far it seems that cams with higher lift seem to lower the power band of a specific duration. For instance, the thunder racing 220/220 on a 112 lsa cam advertises 1500-6500 rpms with .551 valve lift. Texas Speed's 220/220 on a 112 lsa cam advertises 1200-6200 rpms with .581 valve lift. Now is this false advertisment or are the facts right? Anyone have any thoughts or answers? I listed the links below for a look at the two different specs.
http://www.thunderracing.com/catalog...&vid=9&pcid=51
http://www.texas-speed.com/shop/item...d=164&catid=44
Duration and LSA determine the powerband, lift affects the horsepower numbers, if the heads will accomodate. On older cam designs, increased lift would usually increase the duration also, which would affect the powerband. Today's computer designed cam profiles and modern lobe designs can allow for more lift without affecting duration as it used to.
Another thing no one has yet to mention is cylinder pressure increase by means of higher lift cams. Any takers on explaining that one to the original poster? It will answer his question flat out as to why the higher lift pulls the power band down 300 rpms. Any takers before y'all make me explain it in full?
I agree 100%. The cam ramps must be taken into account when determining valve events.
I used the word "powerband" in describing the rpm range of the cams hp. According to my original post, the higher lift cam lowers the rpms in which the cam starts making power. Thats what I meant by "powerband" if that makes since. The overall point to my original post is the fact that I was wondering if the higher lift cams would bring more hp and torque down lower in the rpms vs. a lower lift cam with the same duration?
