Does this look like a lq9?
Old Jul 26, 2012 | 10:06 PM
GMCtrk's Avatar
It annoys me that people even try and pass that off as an LQ9.
Old Jul 26, 2012 | 10:19 PM
jvoisel's Avatar
Yep, me too. Found the listing the $800, texted guy and his first reply was "yep still got it $650 and it's yours" asked him for pics and he sent those two, heads alerted me so I asked him if they were iron or alum and he told me alum 317's. Still didn't look right to me so that's why I posted it. The heads don't bother me but I don't want that longer crank snout.
Old Jul 27, 2012 | 03:26 AM
1FastBrick's Avatar
Custm2500's Rude Friend
The one posted first is definitely Iron heads with the long crank. 99-00
The one shown in the Ebay listing Is 2005 or newer. It has the LS2 Style lifter trays and the LS2 Style rods.
HTH!!!
Old Jul 27, 2012 | 06:22 PM
MPFD's Avatar
11 Second Truck Club
If you don't already have a converter on to fit that will cost the same as a regular one. And will fit any other LS with a $35 spacer plate...
Old Jul 27, 2012 | 06:31 PM
jvoisel's Avatar
I figured that I could just get Chris to make me a custom 60e converter with a 80e front but I'd also like to have it so that if I blow the trans I can put my stock one back in to run while I get the other rebuilt, couldn't do that if the stock 60e converter doesn't fit.. but I may look into the motor still.
Old Jul 27, 2012 | 07:22 PM
2doorfury's Avatar
Originally Posted by 1Bear
The heads look like they’re iron in the pictures which would be from a ’99 / ’00 LQ4 and the crankshaft is sticking out way past the rear seal and would be close to flush if it were a ’01 and up model. Of course if it had the spacer it would look basically the same in regards to distance protruding past the seal, but you would see a parting line and regardless of whether it was actually the long crank or had the spacer, from the factory it would still make it an LQ4, as the LQ9’s came with the 4L65E behind them and all had the short style crank to mate up with it. Another tid-bit, the iron heads would not be 317 castings and would instead be 873 castings.
The LQ9 was most definitely installed in trucks as well as the SUV’s. It was originally introduced for the 2002 Cadillac Escalade, but was released in the 2003 SS Silverado and made into the Sierra Denali lineup in 2005. Of course the VHO and Vortec Max GMT-800 trucks were also blessed with the LQ9 as well.
oh damn, ur right, totally spaced about the ss and vortecmax truck having the lq9 in them.
gmcyukon
Oct 5, 2015 06:20 AM
Wolftrk99
Oct 2, 2015 08:17 AM
LSX-81-SIERRA
Oct 2, 2015 07:05 AM
The_W
Oct 1, 2015 02:35 PM
