Does this look cheesy? Aluminum hardlines to my catch can
Old Sep 12, 2010 | 06:41 PM
  #41
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Eh well gives you somethin to do, plus who doesnt like being crouched under the hood soldering a ton of little wires
Im not putting it on any time soon, headers, efans, ditch the volant, get exhaust fixed then get a bit more comfortable with tuning before it gets put on. So maybe this time next year at the rate I work
Old Sep 12, 2010 | 08:25 PM
  #42
brent5631's Avatar
So when you say your changing the stoich setpoint. Does that only change the cells where you are currently comanding 14.63 or does it scale all of the comanded afr's?
Even at WOT where commanded would be richer than stoich?
Old Sep 13, 2010 | 01:55 AM
  #43
Spoolin's Avatar
GFYS and STFU
Why can't you change the stoich with just the tune? What's the reason for the 8.1L injectors?
Old Sep 13, 2010 | 03:11 AM
  #44
Three6GMC's Avatar
Originally Posted by 2004SSS
i know less bends will result in better flow but you have to get very precise and make every little bend perfect/symetrical to make hard line look good . and a little buffer wheel to shine it up would also help make it look purdy.
^^x2^^
Old Sep 13, 2010 | 08:32 AM
  #45
BlackGMC's Avatar
Resident Retard
you can change the stoich in the tune, and that is what i am planning on doing to compensate for the e10 gas... I got the 8.1L injectors cause the 28s are about 85% now, also hate the damn connectors for them... Rather than spend a few hours trying to get them out, i would just rather cut them off and sodder the truck style connectors back on...
Old Sep 13, 2010 | 08:50 AM
  #46
GMCtrk's Avatar
I compensate for 10% ethanol in my tune at WOT only. 12.3-12.5:1. Cruising is still 14.68:1
GM1697
Oct 20, 2015 12:12 PM
GRRR65GTO
Oct 10, 2015 04:37 PM
old motorhead
Sep 29, 2015 08:22 PM
BigKID
Sep 22, 2015 09:59 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
