Do I need to replace injectors yet?
Old Aug 2, 2009 | 09:42 PM
ihdude's Avatar
Default Do I need to replace injectors yet?
I have a LQ4 in a 01 2500 with a ported and bump mod throttle body, Pacesetters, e-fans, Airaid tube w/ K&N drop in, Wait4Me tune, and 3" true duals (not mandrel) through an x-pipe but with factory cats. At what point should I consider fuel upgrades? What kind of HP at the flywheel am I around?
Old Aug 2, 2009 | 09:52 PM
JakeBrakeIH's Avatar
with a stock cam Id say your fine with stock injectors...depending on the cam that you swap in, it would be wise at that point to upgrade your injectors
Old Aug 2, 2009 | 09:54 PM
Mangled03gmc's Avatar
Baltimore Whore
Your fine with what you have, no need to change.. Your prob around 330 or so crank hp.. You will be close when you slap a cam in,or a blower or nitrous, get a retune, untill then your good as you really don't have a huge amount of mods..
OHsixLS3
Dec 27, 2016 09:30 AM
adunphy
Feb 22, 2016 06:38 PM
05GMC4.8
Aug 7, 2015 09:55 PM
jrplz
Jul 9, 2015 12:07 AM
