Do aftermarket MAFs actually improve performance?
Old Jan 7, 2011 | 09:10 PM
devink's Avatar
Default Do aftermarket MAFs actually improve performance?
Like the title sez........
Old Jan 7, 2011 | 09:39 PM
Atomic's Avatar
I have a gauge for that
No...the MAF is just a sensor. Aftermarket ones can usually read to higher airflow numbers than stock ones, but they wont improve anything by themselves.
Old Jan 7, 2011 | 10:03 PM
devink's Avatar
pretty much what I thought. Sometimes when you read those Summit catalogues you almost get convinced by their gained horsepower figures LOL. At what point HP wise do you need to step up?
Old Jan 7, 2011 | 10:12 PM
00ChevyScott's Avatar
Wearin' da big hat
If you're to that point, you should just tune the MAF out all together.
Old Jan 7, 2011 | 10:27 PM
Atomic's Avatar
512grams/sec
Old Jan 8, 2011 | 05:35 AM
03 BLACKOUTSSS's Avatar
they basically report a higher airflow to the PCM. The maf is a heated wire setup. Air coming through cools the wire, and the pcm calculates the airflow by looking at the amp draw on the maf to maintain a certain wire temp. Aftermarkets report a cooler temp, higher ampdraw which results in more fuel. I used one once, before I was tuned, and was told to get rid of it, or the guy wouldn't tune the PCM for me. He said it was too risky, being that he didn't know what the maf was reporting and wouldn't be able to tune properly. if it your only mod (for me, it was a CAI and a MAF on an LT1) then you'll see some gains, but if you're tuned, dont bother.
Old Jan 8, 2011 | 09:40 AM
Wearin' da big hat
How would dumping more fuel increase power?
Old Jan 8, 2011 | 10:06 AM
Actually they report colder intake temps...
This will give you more timing, making more power..
But like it was said, you can do all this with a tune
GXPJAY
Feb 13, 2022 08:15 AM
Stainless Works
Aug 7, 2015 10:08 AM
V-seriesTech
Jul 28, 2015 12:28 PM
cbhedrick
Jul 20, 2015 10:12 PM
