Disable all TQ management/HPTuners?
Old 04-20-2005, 11:22 PM
what a rush!
moregrip's Avatar
Originally Posted by 02sierraz71_5.3
how about
%torque loss-vs-spark retard
all at 0
hmm, don't know.
anyone? Flyer would know this, but he is out like trout
Old 04-21-2005, 10:59 AM
Weedo's Avatar
I was told NOT to remove the TM entirely. What or how much is supposed to be left in......who knows......
Old 04-21-2005, 11:11 AM
what a rush!
moregrip's Avatar
I've been told lots of things as well. I'm going to take it all out because of the valve body, hardened seperator plate, larger oil cooler, deeper pan I have planned for it, if it goes, it goes, I suspect it will be just fine though.
I have to do something to ensure dominance over a turbo'd denali
Old 04-21-2005, 12:10 PM
Flyer's Avatar
how about
all at 0
There are more than one or 2 that should be 0'd, this is one of them.
Maybe this will help:
Old 04-21-2005, 03:30 PM
Weedo's Avatar
The only way that's going to happen is if you tuck a turbo above your rear so no one knows!!!
Hmmmm, a Radix, with an STS turbo combination.........
Old 04-21-2005, 03:33 PM
what a rush!
moregrip's Avatar
I brought that up about a year ago and most said it wouldn't work, wish I had the $$$ to disprove that.
now that would be a sweet set up
Old 04-21-2005, 05:30 PM
Kano's Avatar
Flyer
how in the hell do you do screenshots
Ive looked for that print button you mentioned a while back
but found nothing
Old 04-21-2005, 06:09 PM
KySilverado's Avatar
Originally Posted by gamedawgx53
Flyer
but found nothing
Windows Key(if this is what you run) + Prnt Scrn , this copies screen to clipboard. Open a graphic app and paste.
Old 04-21-2005, 06:11 PM
Originally Posted by whitt1
Vacuum moduation won't let your line pressures drop during a full throttle shift and your PCM can and sometimes does with cooked clutches being the end result.Transgo does a really neat shift kit with vacuum moduation with a check valve to keep boost from damaging the tranny.You install the kit and then remove all torque management,then set your shift points and converter lockup stratigy then you are good to go.
Is this a special kit or the standard kit you get?
Old 04-21-2005, 06:17 PM
what a rush!
moregrip's Avatar
Its seperate:
http://www.transmissionpartsusa.com/...-046930mod.htm
Quick Reply: Disable all TQ management/HPTuners?
