Disable all TQ management/HPTuners?
Originally Posted by Weedo
I was told NOT to remove the TM entirely. What or how much is supposed to be left in......who knows......
I have to do something to ensure dominance over a turbo'd denali
Originally Posted by 02sierraz71_5.3
how about
%torque loss-vs-spark retard
all at 0
all at 0
Maybe this will help:
Originally Posted by moregrip
I've been told lots of things as well. I'm going to take it all out because of the valve body, hardened seperator plate, larger oil cooler, deeper pan I have planned for it, if it goes, it goes, I suspect it will be just fine though.
Hmmmm, a Radix, with an STS turbo combination.........
Originally Posted by gamedawgx53
Flyer
how in the hell do you do screenshots
Ive looked for that print button you mentioned a while back
but found nothing
but found nothing
Originally Posted by whitt1
Vacuum moduation won't let your line pressures drop during a full throttle shift and your PCM can and sometimes does with cooked clutches being the end result.Transgo does a really neat shift kit with vacuum moduation with a check valve to keep boost from damaging the tranny.You install the kit and then remove all torque management,then set your shift points and converter lockup stratigy then you are good to go.
Originally Posted by KySilverado
Is this a special kit or the standard kit you get?
http://www.transmissionpartsusa.com/...-046930mod.htm
