Differential question
Old Jul 13, 2002 | 02:37 AM
1999stepside's Avatar
Default Differential question
I am gettin a differential cover and I was going to replace the fluid with some Royal Purple. My question is, do I need the posi-addative for the factory G80 locker? And how many quarts do I need to buy. Thanks, Kent.
<small>[ July 13, 2002, 02:39 AM: Message edited by: 1999stepside ]</small>
Old Jul 13, 2002 | 07:16 AM
GREGGO's Avatar
Default Re: Differential question
Yes, you need the additive. As for the ammount, the manua say to keep the level between 15 and 40mm below the fill hole. That (in my case) came to 2 quarts and 346ml out of a third and the additive of 118ml = ~2300ml or ~2.45 quarts Total.
Old Jul 13, 2002 | 10:15 AM
Puffnstuff's Avatar
According to the owners manual the factory eaton g80 gov-lock diff doesn't need any additives.
Old Jul 13, 2002 | 02:10 PM
So that is a yes or a no on the posi addative????
Old Jul 13, 2002 | 03:03 PM
AKZ71's Avatar
I have a factory G80 in mine. I just changed the fluid out last weekend. I was told by the dealer to put it in. The manual for my 2001 does not call for the additive. I replaced what I had in the differential with GM 75w140 for cold weather use plus the GM locking differential additive. I am not sure why the owners manual does not call for it but it doesn't seem a bad idea to put it in. Your call but in my opinion I would say add it.
Old Jul 13, 2002 | 03:25 PM
Puffnstuff's Avatar
No additive is needed for the g80 locking differential. All you need is a good synthetic lubricant like m1 or equivalent that meets the gm specification. Additive is required on limited slip units but not on the g80.
Old Jul 14, 2002 | 03:16 AM
graygmc's Avatar
i bought 3 qts of RP and use all but about half of one.
andrewlong
Nov 9, 2016 09:38 AM
projectnightcrawler
Sep 30, 2015 10:49 PM
chevstang421
Sep 10, 2015 09:16 AM
carid
Sep 10, 2015 09:07 AM
andrewlong
Sep 8, 2015 10:25 PM
