Difference between LQ4 and LQ9??????
Old Feb 6, 2006 | 09:43 AM
Default Difference between LQ4 and LQ9??????
are the pistons the only difference? Are rods and crank of different (cast/forged)??
Old Feb 6, 2006 | 11:27 AM
thunder550's Avatar
High on diesel fumes
Rods are different too, the LQ9 rods are beefier. Crank is the same I believe.
Old Feb 6, 2006 | 06:02 PM
99Silver6.0's Avatar
Ditto on above. Heads same, block same, intake, crank, cam. LQ9 has flat tops versus the LQ4 dished slugs. LQ9 also has bigger bushed rods.
Old Feb 6, 2006 | 06:04 PM
5.3 racer's Avatar
i believe the cranks are balanced differently due to the difference in rod and piston weights, although i've swapped them around with no issues(yet ).
Old Feb 7, 2006 | 10:12 AM
Silverado Desperado's Avatar
What's the CR difference between the 2??
Old Feb 7, 2006 | 11:26 AM
ktmrider's Avatar
I think it is 9.4:1 vs 10.2:1 or so.
natejk
Nov 15, 2016 08:05 AM
Go5.3tt06
25
Sep 4, 2016 10:25 AM
Knightcrawler
Jul 20, 2016 03:29 PM
Justin87gn
Sep 10, 2015 12:06 PM
bisqikss
Sep 8, 2015 03:35 AM
