dex cool
Old Mar 20, 2005 | 06:25 PM
02sierraz71_5.3's Avatar
Default dex cool
can you mix water with the new red coolant gm is using?
Just changed the t stat in the dark and didnt bother thinking about how much coolant I would loose.
also whats the gap on plugs on a 5.3
Old Mar 20, 2005 | 06:29 PM
Yes, should be mixed with H20(50/50)...I believe the gap is .060.
Ryan
Old Mar 20, 2005 | 06:32 PM
Mr. Sandog's Avatar
I would make sure and use distilled water.
Old Mar 20, 2005 | 06:52 PM
is there a draincock on the radiators, mine is a z71 and the bottom of the rad is covered
or should I just flush it through the bottom exit hose
Old Mar 20, 2005 | 06:53 PM
Mr. Sandog's Avatar
Mine doesn't have a petcock.
Old Mar 20, 2005 | 07:50 PM
Kano's Avatar
mine turned green after the cam swap
Old Mar 20, 2005 | 08:46 PM
TarheelZ's Avatar
Hey, Chris, the drain on your radiator should be on the driver's side. There's a drain tube that can be lowered when you open the draincock.
Also, as mentioned, use distilled water instead of tap water. The Dex-cool can be contaminated pretty easily and will turn to sludge in your truck. It's good stuff but there are some precautions to keep it from getting contaminated.
Old Mar 20, 2005 | 08:53 PM
GREGGO's Avatar
I see the draincock and have used it several times during cam swaps and radiator swaps, but....Where is this tube you speak of? Mine no gotty one.
Old Mar 20, 2005 | 08:56 PM
parish8's Avatar
single digit dreamer
i got tired of paying $10/gallon and switched over to the green stuff. i dont really need 5year coolant.
Old Mar 20, 2005 | 09:03 PM
KLUG'S SS's Avatar
FormerVendor
Yeah I found out the hard way about not using distilled water with dex cool. I had a damn overheating problem for about 2 months before I figured out that my radiator was plugged up with all kinds of **** from using the water out of my faucet. It was weird when I bought my new radiator it didn't have the draincock on it but the one that originally came with my truck did.
