in depth ?s about converters and gears
Old Nov 3, 2003 | 10:24 PM
Black Blown 02's Avatar
Originally Posted by 99silveradoSS
Wouldn't I have bad traction problems w/ the 3000 stall on the street?
When you punch it from a stop...Yes... But so do Z06's and Vipers
If you're talking about regular driving, No.
Old Nov 3, 2003 | 10:40 PM
14 Second Truck Club
What about if you slowly take off and punch it ~10-15mph?
I'm seriously considering the tt3000 now
Old Nov 3, 2003 | 10:50 PM
You might turn the tires over a few times at the most, but all in all the tire spin is easy to control.
A looser converter actually gives you better control in the rain, because it takes slightly more throttle to couple up the engine to the tires, and you can bring on the power more gradually.
Old Nov 3, 2003 | 11:07 PM
"A looser converter actually gives you better control in the rain, because it takes slightly more throttle to couple up the engine to the tires, and you can bring on the power more gradually."
So, its harder to control in the rain than the stock converter?
Off the subject, how does the procharger do from a roll? When do you start feeling the boost w/ the 10lb pulley?
Old Nov 4, 2003 | 07:22 PM
No, its EASIER to control in the rain than a stock converter.
The procharger does pretty good from a roll. But it sucks off the line.
When I put the 10lb pulley on I had some major boost issues with the stock intake leaking and blowing off.
I made an intake that wouldn't leak, and it blew the trans the first time I punched it. So I cant really say until I get the trans from level4.
I can say it doesn't start pulling hard until 4500rpm which is about 5psi with the 8psi pulley.
Oobray
Jun 13, 2022 03:38 AM
LCHEE
Oct 24, 2020 04:10 PM
Jake99
Aug 8, 2015 07:56 AM
iregret
Jul 27, 2015 10:32 PM
GMCtrk
Jul 17, 2015 06:39 PM
