Denso 300LPH pump?
Old Aug 18, 2010 | 12:37 PM
Atomic's Avatar
I have a gauge for that
How does this denso compare to the bosch 044?
Old Aug 18, 2010 | 01:57 PM
SYRacing's Avatar
This link should help. It's meant for ricer boys but whatever its good tech
http://www.stealth316.com/2-fuelpumpguide.htm
Old Aug 18, 2010 | 03:01 PM
SILVERADO11's Avatar
Any one know if this pump would work in a flex fuel truck? im not even sure if my flex fuel truck has the same fuel sending unit as a nonflex fuel does.
Old Aug 18, 2010 | 06:59 PM
1faste55's Avatar
Banned
Bosch 044 is old school and I have seen flow tests where they drop off BIG TIME after 60#'s of fuel pressure,not good if you are running much boost.They are crapola for anything forced induction IMO
Old Aug 18, 2010 | 08:15 PM
454SuperSport's Avatar
I'm going to try the Weldon 1100-A pump when i go turbo, i think i've got a good idea about how to do the fuel system so it works like stock. i'll take plenty of pics of the installation so i can make a write-up if it works right
Old Aug 18, 2010 | 09:34 PM
sharpshooter's Avatar
Like Atomic said: how does this Denso compare to the 044?
Old Aug 19, 2010 | 12:40 AM
1faste55's Avatar
Banned
Denso is the best intank you can buy.The 044 is an inline pump that alot of guys put in the tank.
As far as flow ratings,I want to say the 044 is rated a 300lph as well but they flow alot lower than advertised.
Does that anwser your question?
Old Oct 13, 2010 | 11:31 PM
Atomic's Avatar
So has anyone bought and installed one of these? I want to upgrade from my 255 before I go with my new setup...
Old Nov 24, 2010 | 12:56 PM
OnyxSilveradoSS's Avatar
bump, bc I am tired of searching for this to find the info.
I am looking at upgrading my fuel system to under 1000HP. My plan is a denson pump, with a hot wire kit or a boost a pump. my reading is saying if you give this pump good voltage it will out flow the rest.
anyone else looking at this? anyone have a good cheap fuel system upgrade?
Old Nov 24, 2010 | 03:41 PM
brent1976's Avatar
11 Second Club
I am making 62xrwhp and my bosch pump didn't show any signs of stopping. It was making 80psi of fp at wot at 6000rpm when my alternator started dropping voltage to 13v, and it still didn't drop pressure.
$A_Money$81
Mar 27, 2023 10:25 AM
Chavette
Oct 28, 2015 07:33 PM
sTNT971
Sep 26, 2015 04:22 PM
silver-mod-o
Sep 19, 2015 08:46 PM
rednekferlife101
Sep 14, 2015 05:27 PM
