799 flow numbers?
Old Nov 24, 2010 | 06:36 AM
Lowered 93Z's Avatar
Default 799 flow numbers?
Are 799 flow numbers the same as the 243?
Old Nov 24, 2010 | 07:20 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
from everything I've heard and can remember.
Old Nov 24, 2010 | 09:03 AM
I have a set that I can get my hands on and if its worth it I would swap out my 706 for those
Old Nov 24, 2010 | 09:35 AM
trever1t's Avatar
you would need to mill them to keep your CR. They have ~64cc combustion chambers but otherwise a good swap.
Old Nov 24, 2010 | 11:31 AM
The heads are off a 06 5.3 would I still need to mill them?
Old Nov 24, 2010 | 11:46 AM
D_reks{5.3}'s Avatar
The heads are of an 06?? Is it a high output 5.3? Cuz 799s came on some Ls6s and 07+ 5.3s.. You would want to mill them about .010 Which is basically just cleaning the surface, And that would net you about 62cc chambers which is close to the 61cc chamber 5.3 heads..
Old Nov 24, 2010 | 01:14 PM
trever1t's Avatar
Yes. They also came on a limited number of 2005 trucks
The 5.3's with the 799 heads have flat top pistons giving them a CR of 9.9:1
Old Nov 24, 2010 | 04:19 PM
Bumpers's Avatar
as far as i know they are the same... would be a good swap as long as you mill them but i would go 20 thousands or so might as well do it while they are off unless you plan on boosting the engine
Old Nov 24, 2010 | 06:10 PM
Ok the 5.3 is out of a 06 envoy it is the all aluminium block I think so is this a high out put? If so I might just get the whole motor
Old Nov 24, 2010 | 06:13 PM
Bumpers's Avatar
The HO is aluminum block in trucks it was a l33 should have flat top pistons too
SloSVO
Nov 22, 2020 07:34 PM
madmann26
Apr 29, 2020 09:17 AM
OHsixLS3
Nov 22, 2015 07:45 PM
KleanKustoms
Sep 30, 2015 05:07 PM
Rockrz
Sep 29, 2015 09:07 AM
