delete egr/air
Old Feb 10, 2005 | 09:37 AM
GREGGO's Avatar
^^^^^^What they said in the last two posts are why and why not I want to remove it.
Originally Posted by BlackSilver
maybe i'm unclear on this... what is the advantage to removing the egr system?
Old Feb 10, 2005 | 07:45 PM
dewmanshu's Avatar
Moderately Differentiated
Believe it or not, EGR actually decreases cylinder temps and helps to eliminate pinging (one of the by-products of it's design as an emission device). As hot as that exhaust is, it's still cooler than what's going on inside the cylinder. Now, if the engine starts to ping, and the PCM pulls timing, egr deletion just created a loss of power. The pinging alone is wasting power even before the PCM attempts to correct it.
If KR isn't an issue, and the cyl temps are cool enough, then egr will really do very little for you except to save 1/100000000000000000 of the atmosphere, and create carbon build up in places you don't want it.
Pretty Much. Click here for a good read
Old Feb 17, 2005 | 10:44 AM
bodyguard6799's Avatar
Ok, so removing the EGR is not good. There has to be a way to remove it succesfully without problems. What about the EGR restrictor plate mod they have posted on www.sshotrods.com??? I'm about to get a tune and was considering doing some of these. THANKS!!
Old Feb 17, 2005 | 12:35 PM
TXsilverado's Avatar
i would just do the egr mod where you chop off the tip of it. egr shuts off near WOT anyways
Old Feb 17, 2005 | 01:16 PM
rgvsierra's Avatar
Originally Posted by Tiburon
A friend(rgvsierra) of mine took it his off and seems to have gotten good results. Maybe he will post up.
i've been runing w/o it for along time now with no pinging, i did disable the radio button with hptuners,
Old Feb 19, 2005 | 02:56 PM
Damn Good Looking Truck, dude!!!!!!! You have a fine one!
Chewy07
Nov 14, 2015 09:46 PM
OVOAustin
Sep 15, 2015 08:32 PM
chvy=power
Sep 8, 2015 11:06 AM
LQ9Chevy1500
Aug 27, 2015 09:05 PM
