dealership RAPE please help
Old Nov 17, 2004 | 03:26 PM
anthony m's Avatar
Originally Posted by RUINED
anthony,they don't know. thier saying its the airbags, thats all i know? is the sir the module? i think thats what they are saying theres two of...as far as code goes, he told her low impeadence? what does that mean? no p-something number? what else can i ask her?
You need to find out what dtc's are stored in the SDM.It had to set codes unless they are unable to communicate with the SDM.
Old Nov 17, 2004 | 03:35 PM
RUINED's Avatar
anthony, shes on it. as soon as i know i'll post back. thanks
Old Nov 17, 2004 | 03:58 PM
RUINED's Avatar
the tech will only tell her it says "low impedence driver and passenger airbags" that its 2 "modules" that need to be replaced. is there sensors or something that need replacing at a certain point? if so whats up with him charging so much.
Old Nov 17, 2004 | 05:01 PM
anthony m's Avatar
Ok you need to go there and look at the repair order and see what codes the system set.They should be able to tell you that.They need to give you more info than what they are telling you.
Old Nov 17, 2004 | 05:12 PM
GMCtrk's Avatar
they are trying to **** you. they told my dad his truck needed a whole new fuel pump ($650) when all he really needs is the measly fuel gauge sensor replaced ($40)
Old Nov 17, 2004 | 05:20 PM
anthony m's Avatar
Lets not all start bashing the dealers now.Lets get the facts first,air bag parts are expensive.This is why people steal them.
Old Nov 17, 2004 | 07:42 PM
TeamTripp's Avatar
Not all sender cards are available seperatly and not all techs know which ones are/are not serviceable. As reliable as these pump assemblies are, its almost better to do it all at once anyway.
As for the airbags, its unlikely that both went bad at the same time. Get a second opinion and don't tell the second shop about the previous shop. Let them come to there own conclusion first.
Old Nov 17, 2004 | 09:51 PM
chevymec's Avatar
RUINED, This is what Ive found with alot of airbag lights. Sometimes the SDM modules will get a bad connection at the plugs.Usually you can unplug, bend the terminals out a bit and plug it back in. Usually this will fix the problem 90% of the time. If the dealer isnt giving the actual DTC numbers then something is TOO shady.
Old Nov 18, 2004 | 11:59 AM
greentahoe's Avatar
I agree. I dont like when people wont divulge specifics. When I am asked a question pertaining to something I am well versed in, I will give a layman's explanation first. If I am questioned further or with any sort of skepticism than I go into detailed specifics. **** I spent alot of money acquiring all this useless info relating to biochem and pharmaceuticals.
Old Nov 18, 2004 | 12:15 PM
Used - 100 a PCM - IF that is the real problem
Good advise above - get the codes - will tell what is really going on
I have used many used PCM - they are a light switch
They either work or they dont work.
Check any good used part vendor
You would wont PCM's from an unblown vehicle or a flood veh
