dealership RAPE please help
Originally Posted by RUINED
anthony,they don't know. thier saying its the airbags, thats all i know? is the sir the module? i think thats what they are saying theres two of...as far as code goes, he told her low impeadence? what does that mean? no p-something number? what else can i ask her?
the tech will only tell her it says "low impedence driver and passenger airbags" that its 2 "modules" that need to be replaced. is there sensors or something that need replacing at a certain point? if so whats up with him charging so much.
Originally Posted by GMCtrk
they are trying to **** you. they told my dad his truck needed a whole new fuel pump ($650) when all he really needs is the measly fuel gauge sensor replaced ($40)
As for the airbags, its unlikely that both went bad at the same time. Get a second opinion and don't tell the second shop about the previous shop. Let them come to there own conclusion first.
RUINED, This is what Ive found with alot of airbag lights. Sometimes the SDM modules will get a bad connection at the plugs.Usually you can unplug, bend the terminals out a bit and plug it back in. Usually this will fix the problem 90% of the time. If the dealer isnt giving the actual DTC numbers then something is TOO shady.
Used - 100 a PCM - IF that is the real problem
Good advise above - get the codes - will tell what is really going on
I have used many used PCM - they are a light switch
They either work or they dont work.
Check any good used part vendor
You would wont PCM's from an unblown vehicle or a flood veh
