dcr question
Old Jun 5, 2009 | 02:51 PM
006rcsb's Avatar
Default dcr question
I've been thinking my next mod is going to be a cam swap. I find myself looking at the xr259, xr265, xr269 but always coming back to the xr265, seems like the best all around cam, and it has gotten a lot of praise around here. After some talk about dcr i was wondering what kind of dcr that cam would give.
well after playing with this for a while..
http://www.wallaceracing.com/dynamic-cr.php
and plugging in specs using
http://www.compcams.com/Cam_Specs/Ca...csid=1085&sb=2
i came up with
Your dynamic compression ratio is 7.60:1 .
Your dynamic cranking pressure is 148.71 PSI.
which seems kinda low so i went to check out a similar grind from lunati
http://www.lunatipower.com/CamSpecCa...rtNumber=60510
the first thing i noticed is how much sooner the intake valve closes abdc
i went back to the dcr calc and punched in the new # and
Your dynamic compression ratio is 8.89:1 .
Your dynamic cranking pressure is 182.15 PSI.
seems much better to me, like less overlap, less reversion, and more power from a higher effective compression ratio. what do you engine guru's think?
Old Jun 5, 2009 | 03:05 PM
neilownz's Avatar
I have a 60510 that I've been wanting to install in either my car or truck, but I don't know of anyone who runs it. It's their first step LS cam. 60511 and 60512 are a bit more lift. 60511 is probably a better cam, but you would lose bottom end I'm thinking.
http://www.lunatipower.com/CamSpecCa...rtNumber=60511
Old Jun 5, 2009 | 03:22 PM
006rcsb's Avatar
both of those cams are too big for my intended use, the 60512 is huge, it says right on there recommended for 6.6-7.0 not 5.3 dd cams imo
Old Jun 5, 2009 | 03:26 PM
BlackGMC's Avatar
Resident Retard
i came up with
I think yoru calculations are off...
both cams are 212/218
The lunati is 113+4 ~7.72
The Comp is 114+2...~7.54
I believe you plugged in the wrong number cause the small differences in the two cams LSA and ICL does not equate to a difference of ~1.3 DCR.....
Old Jun 5, 2009 | 03:30 PM
006rcsb's Avatar
ok how did you do that, what numbers did you use?
Old Jun 5, 2009 | 03:56 PM
BlackGMC's Avatar
Resident Retard
I used numbers from a 4.8, but here is the spreadsheet i use to calculate DCR, CR and overlap.... The spreadsheet is set up for a LS1
Old Jun 5, 2009 | 04:00 PM
006rcsb's Avatar
hmmmm ok then does the lunati cam look better or should i stick with the xr265?
Old Jun 5, 2009 | 04:01 PM
budhayes3's Avatar
PT's Slowest Truck
IIRC, you want about 7.5 to 8.5 DCR for a street engine on premium fuel...
Old Jun 5, 2009 | 04:02 PM
BlackGMC's Avatar
Resident Retard
Personally i would get 212/218 @ 110+4, but that is just me...
Old Jun 5, 2009 | 04:05 PM
006rcsb's Avatar
hey blackgmc i only have excel viewer, i cant modify the spreadsheet in any way, do you think you could plug in the numbers for the xr259 and xr269 for me too?
xr259
http://www.compcams.com/Cam_Specs/Ca...csid=1084&sb=2
xr269
http://www.compcams.com/Cam_Specs/Ca...csid=1086&sb=2
