dc sport long tube headers?
Old Nov 15, 2007 | 05:44 PM
  #181
mcfarlnd's Avatar
Un-Registered User
got me some of them bitches
Old Nov 15, 2007 | 05:57 PM
  #182
TURBHOE's Avatar
your welcome. . now if only i could get some.
Old Nov 15, 2007 | 08:13 PM
  #183
ForcedTQ's Avatar
Thumbs up
Mine just arrived , got home from work just in time to sign for them! They're pretty nice looking for the price. Now the question is, do I take off work tomorrow to install them and my exhaust?
Old Nov 15, 2007 | 10:18 PM
  #184
Phantom's Avatar
11 Second Club
Originally Posted by 2001CamaroGuy
I'm waiting for them to list another set of the 03+ headers without any air/egr then they are MINE!
why 03+...any of them 99-up will work...
Old Nov 15, 2007 | 10:51 PM
  #185
Stoichiometric's Avatar
The 99-02 have the extra fittings that will need to be capped off.
Old Nov 15, 2007 | 11:47 PM
  #186
ForcedTQ's Avatar
Default Pictures of the AEM Brute Force CHC7602's
These look pretty good overall, I am only concerned with the gap between the primary tubes and the header flange on the Driver's side header. Not a very big gap and the welds on the outside are pretty thick, but I am wondering if I should JB Weld the gap flush, or try to expand the tubing to touch the flange?
Both Headers
Collector
Drivers Side
Passengers Side
Drivers Primaries 5&7
Drivers Primaries 1&3
Any ideas on the primaries to flange fitment? Just deal with it? Thanks!
Old Nov 15, 2007 | 11:55 PM
  #187
BlackGMC's Avatar
Resident Retard
Dont put JB weld in that gap, it could and probably will burn up and then it will screw up your O2 sensors! The only thing to do is weld it, if your concerned that it will leak. But to weld it without screwing up the coating you need to use a wet rag on the outside to keep the temps down, Doing that with small stich welds pausing a couple of seconds between each stich weld should cover the gap and not screw up the coating.
Old Nov 16, 2007 | 12:02 AM
  #188
ForcedTQ's Avatar
Post
BlackGMC, thanks for the advice, I am taking these home with me this weekend to install at my parent's place, my father has been a welder for 30+ years. I know he has a MIG and TIG machine at work he could use to fix these right up. I will make sure he uses a wet rag to insure the integrity of the coating. Small stitch welds it is then! Good looking out! Anyone else notice a gap between the Primary tubes and the header flanges?
Old Nov 16, 2007 | 12:04 AM
  #189
BlackGMC's Avatar
Resident Retard
Use the Tig it is not as hot as a mig, just make sure you don't over heat the coating cause I am pretty sure it needs to be cooked in by exhaust gas to harden.
Old Nov 16, 2007 | 09:51 AM
  #190
Yogi Bear's Avatar
Try placing an exhaust manifold gasket on the header flange and line it up. If the gaps are outside of the holes in the gasket, I wouldn't worry about it.
