damn headers hittin the frame
Old May 21, 2010 | 09:37 PM
cdub81's Avatar
Default damn headers hittin the frame
OK got the pacesetters lt's with y pipe. On the passenger side u can see where its hitting the frame. Sitting in my driveway its not on the frame probably could put 3-4 pieces of paper between it but when the truck turns or is sitting at a weird angle it starts hitting it and it's fuc*king annoying. So what are some methods or options i can do to get it away from the frame
Old May 21, 2010 | 09:46 PM
TIM Z's Avatar
11 sec. Truck Mod
That sucks man.
Try taking a pipe and " tweaking" them maybe ? Or tapping the rubbing spot with a hammer putting a small dent that will clear?
I just installed mine tonight and they fit perfect, no rubbing.
You could also maybe put a wrap or two of header wrap in that area but it will eventually rub thru.
Old May 21, 2010 | 09:56 PM
hirdlej's Avatar
Return them and get another set. They were obviously made incorrectly.
Old May 21, 2010 | 11:12 PM
fredkj3's Avatar
stick a screwdriver in the gap and make the gap wider!! thats what i would do.. i promise you wont notcie a difference.... no one will probably ever even notice... when i put the 80e inn my y pipe was hitting the trans pan.. i pulled the y pipe and beat a flat spot on my y pipe where the trans pan was touching...
Old May 22, 2010 | 08:23 AM
supercharged680's Avatar
i had the same problem.. what i did was loosen up the y pipe bolts and catback bolts.. put a metal sheet between the pipe and frame then re adjusted it kept it for a while and it was fine
Old May 22, 2010 | 08:35 AM
cdub81's Avatar
yea i figured i would get a crowbar or something similar and try to put a "smooth" dent in it just need a little more clearance and all will be good. Was just wondering what others have done thanks fellas
Old May 22, 2010 | 12:22 PM
SnakeOiler's Avatar
This is the best thing to do. I've had to do it with my Dynatechs as well. There is no reason to beat on the metal you just paid good money for.
Old May 22, 2010 | 12:48 PM
mhotrodscooter's Avatar
I had the same problem with my obx's! I loosen my tranmission cross member & prided It over as for as I could & retighten the bolts while holding in place! Also check ur transmission mount it could be broken! Oh I also had to side my motor over! I guess after the swap it wasn't sitting right!
flatblack83
Jan 3, 2026 07:10 PM
Idryfly5
Sep 2, 2022 08:55 PM
gaps
Oct 15, 2015 02:53 PM
Superman09
Sep 25, 2015 05:55 AM
custm2500
Sep 8, 2015 05:53 PM
