Damn G80
Old Apr 9, 2005 | 11:36 PM
02_2500avalanche's Avatar
Default Damn G80
I don't know what I did boys but it sure as hell don't sound good when I take corners. For the past week every time I take a some what sharp right or left hand turn the rear end makes a really loud bang and drags the right rear tire. I pulled the right axel out tonight and everything looked fine but I have yet to take the cover off. I had thought that maybe the g80 was just not unlocking but I had both tires in the air and both were spinning in opposite directions like they should when the diff is unlocked. I find it hard to believe this thing is junk already, there are Dmax's running around with almost 1200lbs of tq and I havent seen of anyone breaking their g80 in the larger 3/4 ton rear ends. If this thing is toast what do you guys suggest for a replacement? I was thinking a power trax loc-rite. Thanks
Alex
Old Apr 10, 2005 | 12:07 AM
Had really good luck out of my Eaton. I would recomend one.
Old Apr 10, 2005 | 09:06 AM
James B.'s Avatar
I've got an Eaton Posi in my 10.5" 14-Bolt. It performs consistently and predictably every time I abuse it. They are not inexpensive but they must be engineered to perfection. I love the thing.
If you order online make sure you get the right one - there are two. One is for 4.10 gears and lower the other is for 4.56 and higher. Run only 80/90 non-synthetic gear lube in an Eaton Posi with 4 or 8 ounces of friction modifier depending on desired firmness.
Old Apr 10, 2005 | 06:11 PM
02sierraz71_5.3's Avatar
Alex
ive heard the powertrax lock very harsh and they arent that strong
jscherbs
Mar 24, 2017 07:20 PM
Wolftrk99
Oct 2, 2015 08:17 AM
RS/SS 4.8
Sep 17, 2015 09:17 PM
97aztecgt
Aug 13, 2015 02:11 PM
