Cutout question
Old Feb 25, 2006 | 11:37 AM
Default Cutout question
How much low-end will I lose with a cutout? Will I gain some mid to top end in the 1/4 mile? Will a cutout be good mod to help traction when I get a TB converter? My mods are on my sig. Thanks!
Old Feb 25, 2006 | 12:32 PM
12 Second Club
You will lose no low end and gain some on the top of every gear. With my cutout open I run a 2.24 60' and a 15.04 @90.35 mph. With it closed I run a 2.29 60' and a 15.18 @89.56 mph. I that is based off of 3 runs with it closed and 3 runs with it open on the same day. So they do help a little. Actually Mine does burn out better with the cutout open. I think in my opionion backpressure is a myth. The way the motor works to make power is the quicker you get air in the quicker you get it out the more power. Just my 2 cents.
Old Feb 25, 2006 | 12:44 PM
ap2002's Avatar
you should loose very little on the low end and gain good on the top, the TB stall should make up for the lowend, so go ahead and do it...
Old Feb 25, 2006 | 01:04 PM
Should I put the cutout before cats or after?
Old Feb 25, 2006 | 03:43 PM
12 Second Club
I would take the cats off. But if you leave them on you will have to put them after the cats.
Old Feb 25, 2006 | 04:47 PM
Alright I appreciate the help guys. Thanks!
Old Feb 25, 2006 | 08:25 PM
goshawk23's Avatar
Truck addict
i didn't lose any low end with my cutouts open. it depends on your exhaust setup as to where you place them.
Old Feb 25, 2006 | 09:15 PM
98TAauto's Avatar
with the cutout open it seems like you are going slower cause the trucks louder:-P
i think some pick up like 2ft pounds with the cutout capped, but they gain 15-20hp with the cutout open depending on your muffler
now putting the cutout before the cats will make you loose low end.. i noticed some below 2000 rpm loss when i deleted my cats
but the stall will make up for any low end loss you have
just put the cutout after the cats and you will be happy
Old Feb 26, 2006 | 11:35 AM
TXsilverado's Avatar
i feel like i lose alot of low end with the cutout open. but...before the longtubes and !cats it felt stronger on the bottom with it open. after the longtubes and ory it feels weaker on bottom with it open but once it gets past 3K it screams. ill see whats going on next time im at the track.
andrewlong
Nov 9, 2016 09:38 AM
projectnightcrawler
Sep 30, 2015 10:49 PM
carid
Sep 10, 2015 09:07 AM
andrewlong
Sep 8, 2015 10:25 PM
Forcefed81
Sep 8, 2015 10:02 PM
