Custom Y-Pipes
Baltimore Whore
Started out with a Y from Lpp, trying to mate it to the stainless works, NA didn't work, so heres what I did. I also made the Y cross after the tranny member for ease of dropping the tranny pan if need be... Also to a Single 4 inch...
That's my old setup that AP is talking about. Check it out when you go and see him. It's a Pacesetter setup, but there's extensions on the pipes after the collectors. I had two flanges welded up after the collectors, and used the stock y-pipe/cat back connection that came with the kit.
it looks very close to this
Baltimore Whore
Thanks.
It also makes pulling the pipes off alot easier, cause your not fighting that member.. Had to trim the top of the member brackets a bit, pull the throttler linkage and fuel lines up a lil, no big deal by any means....
