Custom Intake...
Old May 31, 2006 | 02:33 PM
Hydramatic's Avatar
Default Custom Intake...
Finally got around to taking some pics and video of it. I got everything but the filter at the Performance Depot.
The Movie.
http://s18.photobucket.com/albums/b1...t=MOV00116.flv
Old May 31, 2006 | 02:50 PM
ZR1 DREAMING's Avatar
do you plan on changing the piece that connects to the TB? that is actually the most restrictive part of the stock intake.
Old May 31, 2006 | 02:53 PM
after looking at it closer that piece looks different than the stock one... is that a new part too? if so, I wonder why it still has that dish that sits above the fan shroud and chokes out the tube at the TB
Old May 31, 2006 | 03:04 PM
SS_bnoon_SS's Avatar
I did something similar, but used 3.5" mandrel bends from EBay. https://www.performancetrucks.net/fo...d.php?t=361306
As far as the black plastic piece being the most restrictive part of the stock intake, I sure hope you're right, 'cause this thing sure does like what I've done so far!!!
Old May 31, 2006 | 03:11 PM
Hydramatic's Avatar
yep, that is still the stock resonator. I need to take it off and replace it with something. I was thinking the Airaid MIT or a conduit box jury rigged and painted wrinkle black.
Old May 31, 2006 | 03:58 PM
I've seen 3"-5" aluminum ducting used before if you are trying to save $$, probaly keep the air cooler too...
Old Jun 1, 2006 | 12:58 AM
nichoms's Avatar
i made on for my 02 silverado with the little 4.3 and i used aluminum air conditioner ducting and it worked pretty damn well.
Old Jun 1, 2006 | 04:11 PM
Hydramatic's Avatar
Sounds promising, however, I don't know If I want weak A/C ducting that close to my fan....
Old Jun 1, 2006 | 09:25 PM
jmproductions's Avatar
I wouldn't use aluminum on intake tubing if you can avoid it. It will transfer heat from your engine compartment more easily into your incoming air, might cost you a few ponies. However some polished tubing would sure look cool.
turbo6c3
Oct 5, 2015 06:11 PM
Velocity1
Oct 2, 2015 08:01 AM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
RJaxtheimer
Sep 30, 2015 08:47 PM
sTNT971
Sep 26, 2015 04:22 PM
