Crunch Time!!
Well, it looks like the shop (www.vaspeed.com) will finally get to my motor this week. Hopefully I'll have by next weekend. This will be the setup coming home with me:
6.0 LQ4 Crate Motor, P/P Heads, hopefully ARP Head Studs (Shop can get them at $389
, Need to call Thunder Racing), Fel-Pro Gaskets, 208/216 113 Cam (Until I can get something better), LS6 Springs, Hardened Pushrods, and an ASP Pulley.
Now for a few questions. I should upgrade my injectors correct? Will the Marine 8.1's be too much for the short term? I'll eventually be FI. Also, after this pig is installed, I'll need to fire her up to temp and then retorque the Heads and Springs right? Anything else?
I also have a post in the Appearance section looking for engine dress up suggestions.
Thanks!
, Need to call Thunder Racing), Fel-Pro Gaskets, 208/216 113 Cam (Until I can get something better), LS6 Springs, Hardened Pushrods, and an ASP Pulley.Now for a few questions. I should upgrade my injectors correct? Will the Marine 8.1's be too much for the short term? I'll eventually be FI. Also, after this pig is installed, I'll need to fire her up to temp and then retorque the Heads and Springs right? Anything else?
Thanks!
kr1s
Aug 24, 2015 05:34 PM
smokeshow
Aug 23, 2015 08:23 PM
therock
Aug 23, 2015 01:37 PM
