Crossed Drilled Rotors.....Vol II
Originally Posted by F150boy84
If you truly want better braking capacity. You will need to get a better brand caliper (double piston), bigger rotors and bigger pads made of better material.
THose are the only things that help braking is the braking surface. plain and simple.
Metallic pads are made of at least 60% powdered metal that is pressed into a mold at high temperature with a bit of organic binder to form a somewhat homogeneous block. Most metallic pads have excellent grip at high temperatures but are not suitable for street use because they often are noisy, grip poorly when cold, chew up rotors, and make black dust that gets deposited on the wheels.
And besides the mess of metallic pads, why would another pad be better, considereing budget performance is the goal?
“Better” isn’t a word I’d really use to compare all pads without some kind of application described. Its like saying “what is the best camshaft for a car?” There is no best, just optimized for a specific application. Different pad compositions work well under different conditions. Some brakes actually wont work well on the street but once they are heated up around some twisties, they will blow away the street pads. And there are mixes for everything as well.
I spent more time in braking systems and rotor design, not too much in pads/testing like Nick has. Then again Nick had **** luck of not getting fired so he’s been there twice as long (and just for the record Nick, even if it was the best thing to ever happen to me; I still get pissed off about it and I still plan to run him over with my truck and infest his dog with fleas).
Well I drive my truck very agressivly and want something I can count on in a bind.
Im WOT at almost every light, I hit up the canyons with my stock suspension every other day . Im not worried about warm up really, performance is my main goal with my college student budget in mind.
(BTW- why did you get fired )
Originally Posted by -= MacADaYear =-
Our front brakes are already double piston, and some people cant go bigger on rotors because they use 16" rims.
So now heat dosent play a role in braking distance?
Honestly man you seem like there is some good knowledge locked up in that head of yours but you are too busy bullshitting to let it out.
I just wanna know how to make my braking better since these rotors I just bought dont do anything
