Crazy idea with headers. Do i have room?
Old Nov 20, 2008 | 11:55 AM
Thechevyman122's Avatar
Default Crazy idea with headers. Do i have room?
I want to do some long tube headers on my denali. Im tyring to do it as efficiently and cheaply as possible. Here is what i have: Flowmaster 50 series DI/DO muffler. Factory exhaust system including two cats. If i ran the headers could i put one factory cat after each header then into my di do muffler? that way i wouldnt need a y pipe and could use all my same stuff. If not how much would a high flow cat cost to run after a y pipe. If i do that i will do a cut out and want a fairly quiet muffler that is also cheaper. What are my options on that? Thanks.
Old Nov 20, 2008 | 12:23 PM
BlackGMC's Avatar
Resident Retard
maybe this thread will help...
https://www.performancetrucks.net/fo...d.php?t=377663
Old Nov 20, 2008 | 12:36 PM
so do you have to have either a x pipe or y pipe? I mean would two cats and a muffler not be sufficient back pressure?
Old Nov 21, 2008 | 12:43 AM
anyone? Are my factory cats restrictive? Are they sufficient?
Old Nov 21, 2008 | 12:59 AM
viciousknid's Avatar
Where's the Beef?
These are VERY basic questions that could be answered in just a couple minutes of research.
If you run True duals you don't need X pipe, X-Pipe helps make the flow more efficient between each side of the engine.
You can run LT's and have the Same setup you have now, just buy the headers and go to a muffler shop and have them weld the cats on and run the pipe.
Search is your friend.
walledition
Feb 24, 2026 03:27 PM
gaps
Oct 15, 2015 02:53 PM
Goat's ss
Sep 22, 2015 01:07 PM
5.3lSilverado
Sep 20, 2015 06:48 PM
Lthompson
Sep 15, 2015 07:55 PM
